Question about GE Profile Spectra JGB920SECSS Gas Kitchen Range
STRONG GAS SMELL AFTER OVEN LIGHTS
NO PROBLEM USING THE TOP BURNERS.
THE GAS SMELL CONTINUES AS LONG AS THE OVEN IS ON.
  • sherlockthom Apr 14, 2009
    The problem is with the oven. The gas co. stops be fore the applicance.
  • 10,865 Answers
Call your gas provider as they have a free service whereby they send out a technician with the equipment to check for gas leaks, etc. Do not wait as you may have a dangerous situation there.
Posted on Apr 14, 2009
  • Joe Hogan Apr 14, 2009
    Get a small container of gas leak detector and check each connection yourself. if you find a leak tighten that connection of undo it, pipe dope it and reconnect it.
My Kenmore propane fueled gas oven gives off a powerful strong smell every time it is started. The burners on top do not. Is there any way I can correct this?
this is because the gas is on full before the oven lights
IT is an explosive situation and should be quickly corrected by an accredited gas fitter
the soot indicates an incorrect burn ratio and that will be the major part of the problem
Jan 08, 2016 | Kenmore Elite 30" Stainless Steel...
OK we just converted a brand new natural gas kenmore range to propane and followed the instructions to a tee doing it. The burners are fine and work great, no smell. When the oven is started it smells like...
There is a conversion in the regulator that must be done or the oven flame will not be correct. Usually it is just removing the regulator cap, turning the converter around and putting the cap back on. This may be your problem.
Oct 01, 2014 | Kitchen Ranges
Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Oct 02, 2009 | Kitchen Ranges
Gas smell coming from oven during preheat. once oven is warmed up, smell goes away. I have a Frigidaire FGF366EBC S/N VF6289284.What would cause this?
Typically, all gas operated appliances will get a "gas smell" from time to time. What you're really smelling is the odorant (rotten egg smell) that is added into both propane and natural gas, as these gases have no smell by themselves.
The smell will vary from normal to very strong as the "receipe" for how much ordorant is added into either your propane tanks or the gas supplied to your home. Typically, when tanks start getting low, the smell is more concentrated, while with piped natural gas, the smell can be very strong at different times, based on how and when the gas company adds odorant into the main supply lines.
Usually when a gas appliance is first turned on, the smell can be rather strong, until the gas ignites. So long as your oven is lighting properly, there is nothing to worry about.
However, if you're hearing a rather loud "whoosh" sound as the oven lights, it could be that your ignitor is getting weak and might need to be replaced. If you've got a weak ignitor, it could be allowing a little bit too much gas to build up in the oven compartment before it lights, hence the reason you're smelling the gas.
You can check for a weak ignitor by simply watching the oven when you start it, if the gas lights quickly, once the ignitor is glowing brightly and you've heard the "click" of the gas valve opening (in the oven), then everything is fine.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Kitchen Ranges
Occasional gas smell
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
Oven not working - strong gas ordor
man that is an old oven, according to the diagram ther is a pilot light in the oven compartment , access form the lower drawer/ cover panel, looks like a pilot for sure and problably has blown out
Nov 25, 2008 | Magic Chef 31000 Gas Kitchen Range
How to light Oven Pilot for Magic Chef stove 31000 PAW
There is a cover plate that has two screws holding it down. Inspect the pilot area and you will see a hot surface igniter sitting right next to it.. That is what lights pilot and then the pilot lights main burner. You need a new igniter. Also do not touch any part of the hot surface igniter as human oil will shorten the life of part.
Nov 25, 2008 | GE JGRP17 Gas Single Oven
Mid 90's Magic Chef gas stove
hi there,
since you can smell gas, you have a gas leak. i would recomend checking and cleaning the gas valves. if you can hear sparking, that means it's just the valves. sometimes cleaning the rods will fix the problem.
Oct 10, 2008 | GE JGRP17 Gas Single Oven
GE Profile Spectra JGB920SECSS Gas Kitchen Range Logo
135 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
