Blower won't shut down
I have a three ton York Heat Pump. I noticed the other day that the blower was running all the time. I tried to turn the t-stat off and the blower still kept running. I called a service man and he came out and checked the system. He said that the fan control board was bad. I had it replaced and the system seemed to work fine for about four days and then today it started doing the same thing again. Whats up with this thing?
  • 24 Answers
Is the switch on the thermostat set to auto for the fan?
Posted on Apr 15, 2009
I have a York heat pump AHP42c and the blower is vibrating excessive.
Is anything inside the blower wheel? Check both sides. It could be a paper towel or something else that was sucked into the wheel
Aug 12, 2016 | York 3.5 Ton 13 Seer Heat Pump
Indoor blower won't shut off on heat pump
I would look to replace a relay that is not shutting off or replace the thermostat itself.
Nov 14, 2015 | Honeywell Heating & Cooling
Blower on heat pump blowing with no demand
There is a contact in the blower control card that can stick on. There is also a possibility that the green wire which starts the blower motor could be shorting out with the red wire somewhere inside the thermostat wire. If that is the problem, either pull new thermostat wire, (the rest of the insulation is probably breaking down) or there is some new red link controllers from Honeywell that will completely eliminate wire because the controls are all wireless.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Dear Sir,I have an Amana Distinction 2.0 Ton heat pump, SEER 14 installed in my department about 4 months ago. I've noticed that the AC has a regular pattern running in the on/off cycle and that i
You need a tech. All 14 seer units have an X13 motor which speeds up and down on start up. A tech will adjust your tstat programing. Fan stays on after unit is done cooling to help drain water in cooling and cool off heat strips in heating,
Jun 15, 2013 | Heating & Cooling
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
Outside heating unit runs all the time
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Feb 19, 2010 | Heating & Cooling
I have a Ruud 90% furnace (18 yrs.old) Several days ago, I had a complete ice-over of the evaporator coil. Filters are clean, and airflow unrestricted. After defrosting coil (48 hrs.) while testing, I note...
The motor shutting off after 30-45 seconds means it is probably getting hot and shutting off on thermo overload safety in motor. Two things can cause this: #1 is the motor is defective. #2 the run capacitor has gone bad. If you want to try and save money replace the run capacitor 1st and try it. If that doesn't work replace the motor. You would replace the run capacitor at same time anyway.
Jun 23, 2009 | Ruud UBHC Air Conditioner
1970's Rheem electric furnace
no the older rheems had a sequencer for the heat that turned on the blower at the same time that the heat strios are energized. so the first thing that you need to do is figure out the sequencer that is keeping the fan running and get it replaced.
Jan 30, 2009 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
