Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
51F510 Screen is split in two
When I turn on my TV now I have a black line down the middle about 4" wide. The left part of the picture is on the right and the right is on the left. TV is just over 2 years old. HELP
  • Anonymous Oct 14, 2008
    black line in the middle
  • 375 Answers
Requires service, horizontal fold over and possible other problems to come .
Posted on Apr 13, 2008
Phillips Plasma 42" Solid White and Black Line in Picture
Try to check the part on d convergence board.
Thank you
May 29, 2008 | Philips 42FD9954 42 in. Plasma HDTV
There is a 4 inch wide line across our 51 inch plasma tv. is it fixable
Yes the board to repair is cheaper than tv. As well you can search youtube an get info on how to do it your self. I do my repairs.
Mar 24, 2014 | Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
My TV has a black square in the middle of the picture. How do I fix that?
Your screen is showing a black picture because the closed caption function has been activated. When this closed caption mode is turned on the screen will display an 80% black picture.
To turn off the closed caption and regain a full screen please follow these steps;
1) Press the Menu button
2) Use the up and down arrows to navigate to Closed Caption
3) Use the right or left arrows to select it.
4) Use the right or left arrows to select OFF
5) Use the up or down arrows to select Finish
6) Use the right or left arrows to save the settings and exit.
You should have your full screen back now minus the annoying black box.
Thanks for using FixYa. A rating is appreciated if the solution has worked for you.
Dec 25, 2009 | JVC AV-32D305 32" TV
Black line down the left side of the screen
This is a bad panel. The panel is very expensive to replace. It would be cheaper to buy a new tv. Sorry about the bad news.
Nov 17, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Bowing in the middle like an hour glass
OUCH!!!! Don't kick me...would be my response if I were your TV
Convergence amps problem.
If it works after a kick I'd say poor solder joints on the convergence amp leads
Dec 17, 2006 | Zenith IQB50M90W 50" Rear Projection...
Multiple vertical colored lines on DVD player screen
check this out
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
90 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
