Question about HP 920 Plain Paper Fax
The fax is just beeping, what can this mean?
We just had networking cable corrections made and now I can't get the fax to do anything but beep?
4 Suggested Answers
  • 167 Answers
SOURCE: Fax machine beeping - Samsung SF5100
YOUR PROBLEM IS NOT VERY CLEAR,PLEASE TELL WHETHER--- A. DO YOU GET DIAL TONE ON THE MACHINE? B.WHEN THE MACHINE GETS INCOMING RING -IT IS SET TO ANSWER ON HOW MANY RINGS ? C. SWITCH OFF THE DRPD MODE. D,CLEAR THE MEMORY OF THE MACHINE TO FACTORY DEAFULT BY--SWITCHING ON THE MACHINE WHILE HOLDING THE STOP BUTTON AND THEN COOSING YOUR COUNTRY WHEN PROMPTED. SHOULD TAKE CARE OF THE PROBLEM... HAPPY FAXING OMNIPRESENT
Posted on Sep 25, 2007
leroyal
  • 2120 Answers
SOURCE: Faxjet 525 will not send faxes
it is never getting a dial-tone. Phone line should be plugged into the LINE port.
Posted on Jan 29, 2009
ic0729
  • 212 Answers
SOURCE: I place my paper that I want to fax in the fax
1) did you dial correctly?
2) are you in an office or in your own home?
a) if you are in an office, you may have to dial a 9 or someother number to dial out before you can type in your original fax number.
b) if you are in your home, then its a number of things: Fax machine not connected with phone lines properly is one big supect. Check your phone cables to make sure that the fax machine is properly connected.
Posted on Mar 05, 2010
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the...
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
Jun 18, 2011 | Compaq AlphaStation XP1000 PC Desktop
I am repairing a computer for a friend. When I start the computer I get a continual short beeps. I have checked connections but nothing shows bad. The computer worked fine previously and I haven't...
depending on the number of beeps and their durations you can search your motherboards bios beep codes which should tell you the general area of the fail
try unplugging and re-seating memory cpu videocard / monitor
these are the usual main culprits
May 06, 2011 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
I have a proline w76s laptop, it had a loose ht cable, i dismantled it to put the cable in its proper position but when i assemble it back its giving me a continuous beep and it restart after a few...
You either have a loose cable, or your RAM is not inserted correctly. First check your RAM and try reinstalling it. Then if you still get beeps, unfortunately you probably need to disassemble and check all your corrections. The beeps mean that something is loose, missing, or broken.
May 05, 2011 | Computers & Internet
I place my paper that I want to fax in the fax machine,dial the number that I want to fax, push start, it scans the paper, I hear the fax tone and at the end I get a Beep Beep Beep and the report sending...
Mar 05, 2010 | HP 1040 Plain Paper Inkjet Fax
DX-800 beeps with Incomplete Info Code = 720
Error Code 720: Cannot connect to the Pop Server. (Incorrect Pop Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the network Administrator
Regarding the beeping noises. The DX-800 has multiple settings for beeps, rings and the dialing monitor. If it is the latter, press MONITOR button once, then press the DOWN arrow, until silenced. Some ringer/beep settings are under Fax Parameters, some are in a special SERVICE MODE.
let us know if you can isolate which one and we can help turn it off. At least now you know what the 720 code means.
Good Luck!
Nov 10, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Jan 28, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Fax beeping after a message was sent out.
It means it never found a dial tone. Check the line with a regular phone.
Jan 26, 2009 | Office Equipment & Supplies
Key pad on brother 1020e fax mc seems to be locked when you press copy for ex it just beeps 3 times
When the Brother machines beep three times while pressing any button on the front panel, this means there is a button stuck. Try pressing all buttons over and over to unstick button. This should help. Please rate my help if this works. If you need anything else, save my user name and ask me anytime. Thanks!
Jan 21, 2009 | Brother FAX-1020e Plain Paper Thermal...
I have a Brother Fax-920 which gives an 8 beep error signal. What does this mean and how do I fix it?
Spoke to the manufacturer and he said 8-beeps at a steady pitch indicate a problem with the sending fax machine not with mine.
Jul 15, 2008 | Brother Office Equipment & Supplies
HP 920 Plain Paper Fax Logo
62 people viewed this question
Seeker5211
Seeker5211
