Question about Sharp AR-M350U Copier
Sharp ar-m350u error code h5-01. How do I fix
Sharp ar-m350u error code h5-01. How do I fix this?
  • 62 Answers
Error code F1-15
You have a problem with tray movement in the finisher/sorter area. Sometimes those trays get slightly bnt if somebody leans on them and they dont strike the sensor in the center properly. If not then maybe the upper and lower limit sensors need to be cleaned or replaced
Jul 24, 2012 | Sharp AR-M350U Copier
Tip
F2-02 error code on Sharp AR-M350/450 and 355/455 Copiers
The F2-02 code will often be the result of a defective or after market toner cartridge. Try replacing the cartridge and power cycling the copier before placing an expensive service call.
on May 17, 2010 | Sharp AR-M350U Copier
Hi I have a sharp ar-m350u that has an error code l6-10 on the screen, what does this mean and how can i fix it , cheers
check the laser scanning unit LSU (black box). it may be ur polygon motor inside has a problem. check also the harnesh/connector or its board.
Jun 02, 2011 | Sharp AR-5320 Black and White Copier
U6-03 error on sharp ar-m350... is there a code i can type in to fix it?
Tray 3 is not lifting or lowering properly. There could be a bad lift motor on the tray. The tray could have a bad sensor. Someting is either not moving the tray up and down or the sensors are not detecting the movement.
Remove the paper and the tray, inspect the tray , see if it moves freely, look for something bent or out of place.
U6-03 indicated a tray three lift problem.
Aug 09, 2010 | Sharp AR-M350U Copier
Sharp AR-M350U Copier/Printer Error Code F2-00
clean developer unit connector .pull out , clean , then insert .
May 25, 2010 | Sharp AR-M350U Copier
I have a problem with a AR-M350U. Bottom half of
charge ?
also drum earth could be a factor.
Feb 08, 2010 | Sharp AR-M350U Copier
Error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
May 07, 2009 | Sharp AR-M350U Copier
Error code h5-01
Hello sir; the paper exit sensor get stock, just put back in the track let it moved free.
Apr 14, 2009 | Sharp AR-M350U Copier
Error code l6-10 on a sharp ar-m350u
I can't find a table of Sharp error codes.
Do all documents have this problem? Then I would contact an authorized Sharp repair center.
If there's only one document that does this, it could be a corrupt or very large file that the printer can't handle. Try sending a single page of the document instead of the whole thing.
Isn't the AR-M350U a "Corporate" multifunction device? Then your vendor should be providing warranty support or service contract support for it. Check with the vendor before getting involved with another company.
Jul 18, 2008 | Sharp Computers & Internet
Sharp AR-M350U Copier Logo
1,379 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
