First guess is not enough airflow -- See how much air is blowing out the exhaust vent. If it seems weak, first make sure there is no excess lint in the exhaust path (check inside the dryer as well as the exhaust hose). If there still isn't enough air moving, the blower fan is likely loose on its shaft. If the dryer is overheating and you have very strong airflow, then the temperature detectors in the exhaust path are probably not ever telling the heating element it's warm enough. Check for loose wires, or you might have to replace the detector.
My Speed Queen model AES17 leaves small black marks on the clothes. Brand new machine. I have heard...
(More)
My Speed Queen model AES17 leaves small black marks on the clothes. Brand new machine. I have heard it comes from worn rollers. Like I said, brand new machine, so whatever the reason, I will never waste me money on Speed Queen again. I guess this is company that does not spend time on quality control.
GE dryer push start button dryer starts release start button dryer stops. (will run and heat as long...
(More)
GE dryer push start button dryer starts release start button dryer stops. (will run and heat as long as you hold the start button down)
My AES17 dryer leaves black marks on the clothes off of the rubber gasket at the rear of the drum,...
(More)
My AES17 dryer leaves black marks on the clothes off of the rubber gasket at the rear of the drum, inside the dryer. It is the only place black marks could be coming from, and the marks look just like something black was rubbing against the fabric.
I thought it was my washer, I put pillows in my dryer on hot for and hour to kill whatever, now they have the black marks all over them. This has been going on for a while now. It usually happens to my sheets, and a few whites. I don't put most of my clothes in the dryer. GE up right lg. capacity 5 years old. I wish I knew if this was fixable? If anyone has a clue?
