Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Maytag frontload washer door is leaking
By MAYTAGGIRL on Sep 13, 2007
hi...i have a maytag frontload washer and there is a lot of water and suds leaking out the bottom and sides of the door. it is a circular clear door. inside there is gray stretchy lining around the door and this wire circle with a spring at the top came out of it. i know it must be the source of the problem and can probably manage to put it back in place myself...i just don't know where that place is! please help!
Comments:
Sep 14, 2007
- thanks so much! it worked!
Same Problem
Dec 18, 2008
-   Thanks my friend! Google'd and found your solution and it worked. Thanks again!!! -   Guest
Best Solution
posted on Sep 13, 2007
Helpful)
Krazytech
Rank: Guru
Rating: 90%, 650 votes
Yes you can do it. the door boot has come off the tub opening. first you will have to push on the door boot (gray rubber)on. There is a grove that slides into the metal opening in the washer. make sure the the door boot (gray rubber)lays flat against the outer opening. then with the spring at the bottom . start at the top put the wire in the rubber grove. until you get the the spring then pull down on the spring and tuck it into the grove.. I hope this helped [lease let me know if you get it... krazytech
Comments:
Sep 14, 2007
- Great to hear that you are back in business.
Please take a moment too rate the solution. It will help my ratings..
Krazytech
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
What is the most reliable top loader washer to buy?
Answer
is the ge whre550kww a good washing machine.
Answer
Samsung front load washer keeps getting E7 and E3 what is this?
Answer
The light is flashing red: intake and drain
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14830
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
