Question about JVC DRM10 DVD Recorder
Green Video Light constantly on. will not operate at all
I have a JVC DRM10 DVD Recorder. The green video light is constantly on and it will not switch on it seems to be locked. Can you help please
Hello, I have the same problem, did you manage to fix this problem? Thank you
Posted on Mar 16, 2010
  • ed z
    ed z Jun 17, 2014
    mine does the same , still no answer ???
How to connect Hitachi camcoder with laptop
Connecting to PC via PC Connection Cable
Use the provided PC connection cable to connect the DVD video camera/recorder to PC as shown in the last.
Note:
• No data can be written to the HDD, disc or SD memory card in this DVD video camera/recorder when it is connected to PC.
• The PC connection cable does not supply power to the DVD video camera/recorder: Use the AC adapter/charger
to power the DVD video camera/recorder.
• Before connecting the DVD video camera/recorder to PC, disconnect any cables or camera accessories (external
video flash, external microphone, etc.) other than the PC connection cable and AC adapter/charger.
• When connecting the DVD video camera/recorder to PC, the ACCESS/PC indicator will light green. While HDD or
a disc is being accessed, the indicator will light or blink orange. While an SD memory card is being accessed, the
CARD ACCESS indicator will light or blink red.
If you connect the DVD video camera/recorder to PC via PC connection cable, the PC will automatically recognise the DVD video camera/recorder. After recognition is finished, it may be
prompted to restart the PC: In this case, follow the instruction and restart the PC.
Mar 11, 2012 | Hitachi Video Cameras
I have a jvc kdavx1 trying to hook up to a 2000 buick reagal need to know how the wires hook up
Please let me know if you have questions, and thanks for using FixYa.
2000 Buick Regal Car Stereo Install Diagram jvc kdavx1
Radio Constant 12V+ Wire: Orange yellow
Radio Ignition Switched 12V+ Wire: Yellow red
Radio Ground Wire: Black/White black
Radio Illumination Wire: Gray/Black orange/white
Left Front Speaker Wire (+): Tan white
Left Front Speaker Wire (-): Gray white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Dark Green gray/black
Left Rear Speaker Wire (+): Brown green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Dark Blue purple
Right Rear Speaker Wire (-): Light Blue purple/black
parking brake: blue light green
For this last wire, access the back of the parking brake to find a switch with a blue wire. Peel some insulation from the wire and wrap the stripped end of a 3 foot piece of 16 or 18 gauge wire around the stripped section. Solder and wrap the connection with electrical tape, route the wire to the jvc, then strip and solder the other end to the pigtail of the head unit.
If you are also installing a camera seeing behind you when backing, you will need to run a wire to the back-up light on the driver side reverse light (light green) wire along with your video cable.
May 30, 2011 | JVC Car Audio & Video
Loading keeps blinking Nothing works anymore. even power of no longer works
Check for dried up electrolytic capacitors on the DC-DC converter C5318, C5340, etc.
Nov 13, 2009 | JVC DR-MH30S DVD Recorder
Hello
You should first ensure that all the cable connections are firmly affixed both to the dvd recorder and the tv you are trying to use it with.
Secondly - it could be due to settings on your tv that the player isnt working. Check through your TV's manual for tips on how to adjust all the settings on your tv.
If all else fails return the unit. Send it back to whereever you bought it form or if its still in warranty, back to the manufacturer.
Nick
Sep 03, 2009 | JVC DRM10 DVD Recorder
The blinking blue light on my JVC DR-M10 will not stop and disabe
The problem with these units is the filter capacitors in the power supply. They should be removed and replaced with 25 v.dc capacitors...total cost for the capacitors £5. If you don't fancy doing the repair your self, perhaps you know of a good friend who can use a soldering iron!
The capacitors are 2200 micro farads radial mounting, 680 and 1200, all should be at least 25v dc working for a reliable recorder. The existing ones are prone to "leaking" and should never have been used...shame on you JVC!
Regards,
John Saunders
Dec 22, 2008 | JVC DRM10 DVD Recorder
Darn blue loading light won't stop
Regards,
John Saunders
Mar 11, 2008 | JVC DRM10 DVD Recorder
Loading blue light
Contact JVC @ 800-252-5722, the "loading" is a known bug and they will fix this defect at n/c even if it's out of warranty period.
Feb 17, 2008 | JVC DRM10 DVD Recorder
I got a ?
Normally, the emergency/parking brake has to be activated/engaged for the video player to operate.
By bypassing, you are simulating this condition even if in reality, the emergency/parking brake is not activated/engaged.
Solution > ground the video player's brake sensor wire rather than connect it to its intended connection point.
In some brands/model/versions of the video player, this would be light green (Pioneer, Clarion, JVC), green (Kenwood),
In some other rands/model/versions of the video player, there would be a bypass switch underneath a sticker, others would need a special adapter, still others have bypass option/feature in the menu/setup and some would require a toggle switch that would connect the dvd brake wire from positive to ground.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information. A reminder pls, in some regions bypassing is not allowed.
Good luck and kind regards.
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
JVC DRM10 DVD Recorder Problem
This unit is showing and error message "Disc Not Recordable" with a maxell DVD-R 1-16 Speed Single Sided Recordable DVD.
Nov 09, 2007 | JVC DRM10 DVD Recorder
1998 CHEV CORVETTE...I'M INSTALLING JVC KW-AVX800 IN DASH VIDEO DVD CD PLAYER AND 2 AMPS . ONE AMP IS A 2400 MONO D BLOCK BLITZ FOR THE SUBS ...AND A 1200 WATT FOSGATE AMP FOR THE HIGHES AND THE MIDS
For a JVC KW-AVX800 wiring would be:
Black - chassis ground/negative
Yellow - always on B+ (12V + terminal of battery)
Red - Accessory B+ (goes to 12V when ign key is switched to Acc)
Blue - Power/motor of antenna
Blue/White - remote trigger on of external devices such as an amplifier
Orange/White - park light
Brown - mobile phone sensor
Light Green - parking brake
White & White/Black - left front
Gray & Gray/Black - right front
Green & Green/Black - left rear
Purple & Purple/Black - right rear
Hope this be of some help/idea. Post back should you need additional information.
Nov 03, 2007 | Car Audio & Video
JVC DRM10 DVD Recorder Logo
175 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
