Question about Abit BE6-II Motherboard
Abit be-6 II with PIII-1000 (coppermine) doesnt boot(bios ver. beh70=latest)
3 Suggested Answers
mbase213
  • 728 Answers
SOURCE: Manual and Bios for Abit AB9 Pro Motherboard
Hello seany187,
What I'm doing since your system doesn't want to download from Abit, is creating a zip file with all the drives, manuals, utilities and bios updates for both XP, XP64, Vista, and Vista 64, since I don't what OS your on, and you will be able to download them from this private site HERE. And because the files are so large, I split them into, I'll post the second one as in a comment as soon as it's completely up on the site.. You shouldn't have any problems with these downloads, unless you have your IE settings to high.
Good Luck & don't forget to leave a rating based on my Solution.
Thanks Mark
Stay tuned for the second file!
Posted on Apr 07, 2009
SOURCE: bios is not working properly
reset the bios how can you reset the bios open the cover the following instruction and there is a jumper convert into the second jumper then it will be reset
Posted on Apr 09, 2009
How to acsess the boot device menu at post on abit il8 motherboard
.Abit did not add the BIOS post to the manual.
Watch the BIOS post, most all motherboards have the hot-key menu at BIOS post.
If for some reason the hot-key is not reported on BIOS post, then you hit the DELETE key and enter the BIOS, Advanced BIOS Features Setup Menu and set what hardware you want to boot first, under Hard Disk Boot Priority, set First Boot Device
Mar 31, 2013 | Abit IL8 Motherboard
Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
Nov 28, 2009 | Abit KV7-V Motherboard
Hi , my abit pro 9 bios doesnt safe ,,want to install windows on a new empty drive but therefor i need to change boot device , i choose cd rom , then F10 to safe , but it freezes there , doesnt safe ,,,...
for your first boot cd/dvd rom, 2nd boot hdd is it serial ide or sata, then you can disable the 3rd boot device, if it freezes and does not save reboot your pc in some motherboard there is key to press for you choose which device to boot first if you find the key sometimes its f12 or f10 when press this it will promt which device to boot first then choose which of those devices you want to boot first
Oct 22, 2009 | Abit AB9 Pro Motherboard
Long POST and will not mount HDD.
first of all, you need to another 512Mb of memoires. it will run better. second, go to BIOS and search for boot order, chaneg the the boot order to Hard driver first.
May 01, 2009 | Computers & Internet
Bios is not working properly
Apr 09, 2009 | Abit BD7-E Motherboard
Motherboard doesnt post if you change any of the settings
Sounds to me like you have a bad CMOS battery. That battery provides enough juice to keep the hardware clock and settings active. The battery should be a size 2032 and you can find a energizer brand at any store almost. Shouldn't cost more than a couple of dollars. Let me know if that does the trick.
Mar 13, 2009 | Abit KD7 Motherboard
BIOS UPDATE FAIL
Try making a disk again - use a brand new disk and check it for errors.
Feb 15, 2009 | Abit NF-M2S Motherboard
I have 810 bu mother board
your board is compatible with pentium 3 processors through the "coppermine" revision, the pentium 3 "tulatin is not supported" here is a list from wikipedia of the "coppermine" processors supported by your board.:
Coppermine
  • 100 MHz FSB: 500, 550, 600, 650, 700, 750, 800, 850, 900, 1000, 1100 MHz (E-Models)
  • 133 MHz FSB: 533, 600, 667, 733, 800, 866, 933, 1000, 1133 MHz (EB-Models)
Coppermine-T (the only coppermines with an attached heatsink)
  • 133 MHz FSB: 800, 866, 933, 1000, 1133 MHz
The Tulatin core is NOT compatible with intel 810 boards, and they can be easily confused with the coppermine-t's because they also have attached heatsinks.
Aug 20, 2008 | Intel SuperMicro SUPER Motherboard - 810...
Xp restarts after
Your OS has a problem,
Try to repair it or just install a new copy of OS
^_^
Mar 14, 2008 | Computers & Internet
Abit BE6-II Motherboard Logo
56 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
