Question about Canon imageRUNNER C3170U Color Copier
I need to setup an ip address in the imagerunner c3170u
Where do I find the menu to setup for ip network
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 153 Answers
Additional functions,system settings, network settings, ip address
canon tech
Posted on Apr 19, 2009
Imagerunner 210S. I have a network card in this used printer but my computer does not see it. How do I install this printer on my home network? Is there an adapter to plug into the ethernet jack to...
  1. You need to set a Static IP address in the printer:
  2. Press the "Additional Functions" key on the Canon Imagerunner 210N keypad.
  3. Tap "System Settings" and enter your administrative ID number and passcode if prompted.
  4. Tap the "Network Settings" button and tap the button next to "TCP/IP Settings."
  5. Press the "IP Settings" button.
  6. Highlight "IP Address" and use the keypad to enter the IP address you want to assign to your Canon Imagerunner 210N.
  7. Fill in the "Subnet Mask" and "Gateway Address" fields with the appropriate information.
  8. Press the "OK" button to save the network settings and enable the new IP address.
Read more: How to Set the IP Address on Canon Imagerunner 210 N ' eHow.com http://www.ehow.com/how_7427700_set-canon-imagerunner-210-n.html#ixzz19ZSyEw8N Then install the driver and poit them to the IP address.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 30, 2010 | Computers & Internet
My printer is not communicating with my network? I have tried to ping the IP address several times and it results in timed out. HELP, How do I reset the IP address in the system. I had to replace our...
Go to Additional Function > System settings > Network Settings > IPv4 Settings >
* IP Address
* Subnet Mask
* Gateway
Or you can turn ON the DHCP on the machine, Additional Function > System settings > Network Settings > IPv4 Settings (you can explore on these menu). Once the machine has detected an IP Address, turn OFF the DHCP. View the IP Address and use this during installation of the driver to set the Port.
Nov 01, 2010 | Canon imageRUNNER 1023iF Black and White...
I HAVE ONE IRC 3200 AND I DONT KNOW WHAT DRIVER INSTALL FOR SCAN AND PRINT, I HAVE WIN XP
Go to http://www.usa.canon.com
Select Downloads
Select Office/Production
On next page from the dropdown select Office/Production products again
Next page Select Networked Office Systems/Copiers
Next Page select Color ImageRunner Series
Next Page Select Color ImageRunner Series
From List select Color Image Runner Irc-3200
From the choices select the driver needed. PCL or PS (postscript)
Select either Setup or INF.
If Setup or INF file. Download the zipped file. Create a folder on desktop or downloads. Call it Canon Copier or whatever. Download the zipped file to this folder. Go to the folder you downloaded the zipped file to and double click on the file. When Win-Zip started and asks where you want the file un-zipped to enter a period (.) this will unzip the file to the folder you created.
Once the file is un-zipped if you downloaded the setup file run setup exe.
At somepoint in the setup process you will be asked which port you want to use. You will need the IP Address of the copier ( which can be obtained by pressing the additional Functions key on the copier, selecting report settings, selecting Network and print report. If the IP address needs to changed select additional functions again, Select System settings Key, Network settings key, TCP/IP settings, Check or Set IP Address here or select DHCP to get new address. Repower the copier if any changes are made.
At the which port to use select New Port, select Standard TCP/IP port and create new port. Enter IP address in the new port window.
If using INF file after INF is unzipped. Go to Printers folder and select create New Printer. Follow Printer Wizard. Create New Standard TCP/IP port. When the Wizard Asks for Driver, select have Disk and browse to the folder you created and click the unzipped file and continue clicking until the file installs.
Mar 20, 2010 | Canon imageRUNNER C3200 Copier
Canon imagerunner c3100n Howe do I remove
Your in the copiers IP address into your web browser and go to address book and delete address , you can also add address's here. If you do not know IP address, go to machine, touch additional functions, system settings, network settings, tcp/ip, IP and write down #.
Oct 30, 2009 | Canon imageRunner C3100 Copier
How to configure imagerunner c3100 as a printer on a network
what do you need to know?
you need to put a static IP address or set it to DHCP and load the canon print driver.
you need to create a tcp/ip port on the ip address of the copier
Aug 22, 2009 | Canon imageRunner C3100 Copier
Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Mar 12, 2009 | Xerox Phaser 8500/DN Printer
Canon Imagerunner color 3200 copier
you need to load the copier drivers into your server you can down load these drivers from canon website /or your network outlet is not setup
Dec 05, 2008 | Canon imageRUNNER C3200 Copier
Imagerunner 5000s scanning problem
run the network scangear utility from the start menu. Click "discover scanner", when the discovery is finished select your copier and then click apply.
May 28, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER C3170U Color Copier Logo
1,621 people viewed this question
old marine
old marine
