Battery for TransPart GX3 holds only 3 minute charge. When it goes, the power plug for AC falls out. Any suggestions others than new battery I cannot afford at this time. Thanks Barb232
Where the power cable connects to the computer. i was told that the plug-in is magnetic. So if this is true does the dead battery have anythign to do with it falling out?Where the power cable connects to the computer. i was told that the plug-in is magnetic. So if this is true does the dead battery have anythign to do with it falling out?
it may have damaged solder connections where the plug on the back of the computer connect to the motherboard. this is very common when the cable gets plugged and unplugged frequently.
try holding the cable in different positions while its powered up , see if you can get the power light to flicker. also check the cable's voltage if you know how to use a voltmeter. post again here if ya need more help..it may have damaged solder connections where the plug on the back of the computer connect to the motherboard. this is very common when the cable gets plugged and unplugged frequently.
Are we speaking about the wall outlet OR where the power cable is connected to the computer OR where the battery connects to the computer?Are we speaking about the wall outlet OR where the power cable is connected to the computer OR where the battery connects to the computer?
You can't post conmments that contain an email address.
1) When plugged into power, and plugged into the laptop, gently wiggle the cable from the AC adapter TO laptop.
Any change?
Do the same on the power cord TO AC adapter.
NO? Go on.
2) The port on the laptop that the plug from the AC adapter plugs into, is the DC Power Jack. If we are discussing an Acer Aspire 5738Z Notebook PC, the DC Power Jack resembles this one, (Not installed),
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
This sounds like the laptop is faulty if within minutes the laptop is totally drained of power from a so-called full charge. Because the laptop is new then I recommend that you send or take the laptop back for repair or replacement as it's still covered by the manufacturers warranty.
first, check that the battery connection isn't blocked by a sticker or something. second: try disconnecting the battery and ac and hold the power button for 1 minute. then give the battery and ac another try.
let us know how it goes.
if it still doesn't work, time for a warranty replacement.
Ahh, the notorious battery problem. I had (2) units that would not charge or turn on (red light just kept flashing). I opened the unit and disconnected the battery on (1) and completely removed the leaking battery on the other since I could not find replacements batteries. The units work fine now when plugged in (AC or DC adapter of course !). Still looking for a replacement battery...
it may need to be left on charge for a while...
when u first boot by pressing power wait for a minute or so and press and hold power button til shut down then try reboot..also try boot from disk....need to distinguish whether motherboard or software issue.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Sounds Like From Your Description That You Need Your DC Jack Repaired/Replaced..
THe DC Jack Is the Port where Your AC Adapter Plug Plugs into on the laptop.... THis can be proprietary or non proprietary.... But Either way, the Old Faulty Jack Needs To Be Desoldered and Removed, THe Board Cleaned and a New DC Jack Soldered On.. You Will Then Be able To Power On Laptop With AC Charger and Will again Be Able To CHarge The Battery..
