As soon i turn it on it shuts off with a flash i hear the fan for a second and off it goes
As soon as i turn the computer on i hear the fan for a second and a flash and it turns off
  • Basilio Guzman
    Basilio Guzman May 11, 2010
    Ok, please note if the processor fan is running, because desktop PCs have additional fan. The processor fan MUST be working, because the heat produced by the processor will fry a system in 5 seconds at the higher temperature. It is easy to see when you start your PC with the side panel removed. By the way, if the processor fan is the culprit, it can be easily replaced (I recommend to replace the heatsink, it cost about $15 for a Pentium 4 or Dual Core).
    Sergeant:
  • 263 Answers
It's shutting down because it's too hot check the fan assembly is secured firmly into it's slot..cos it may be loose.
Posted on Jul 29, 2009
I have a Phillips big screen tv and the front light is flashing red at all times and the picture will not come on the screen. This light is usually green when the set is on. What can I do to get it green...
I have the SAME issue and so far it seems to be an issue with the fan not kicking on.... I turn it on in the morning, as soon as you hear sound the red lights kick on and I shut it off... it takes a few seconds to shut down so stay close to your remote durring this process and as soon as the "red light" kicks in, turn it off, as soon as it's off, turn it back on... I have to go thru this about 30 times now before I can get the picture to stay on, but it eventually kicks in. Hope this helps!
Aug 24, 2010 | Philips GOGEAR SA6045 MP3 Player
Computer is a Lenovo TC M52 P4 / 3.2 - I have added a sound card, a PCI express Geforce graphics card and a NIC card. The problem seems to be overheating as it only shuts down like this during the summer...
The case fan should start running as soon as you turn on the computer. I would replace the fan with a higher capacity (CFM). If you have a case that can take 2 case fans, I would install the send fan. Also with the case off, check that the CPU cooler fan is functioning. With the quick shut off, I would suspect that the CPU cooler fan is not functioning. I could be impeded by dust. Vacuum and blow out any dust on the motherboard, fans and battery fan while you have the case off.
This should aleviate the shutoff problem due to overheating.
Let me know if this solves the problem.
Please rate this solutution. Thanks.
Jun 23, 2010 | Lenovo ThinkCentre M52 8212 - Pentium D...
Satellite P35-S611 (PSP30U20H001) PC Notebook: what causes the p 35/30 shut down as soon as you t...
The processor is over heating. I have a p-35 s6053 and it used to do the same thing until I fixed it.
Do the fans come on or anything when you first try to turn it on ??????
I'd bet the fans come on strong and then after about 5-60 seconds it just shuts off. let me know if i'm right and I can tell you how to fix it,
May 17, 2010 | Toshiba Satellite P35-S611 Notebook
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
AKAI PT50DL14X\SMS - LAMP INDICATOR (GREEN)
AKAI PT50DL14XSMS - LAMP INDICATOR (GREEN) FLASHES ABOUT 20 TIMES - CAN HEAR FAN RUNNING AND LOOKING THRU LAMP GRILLES CAN SEE BRIGHT BULB LITE - NO PICTURE COMES ON - AFTER ABOUT 30 SECONDS EVRYTHING SHUTS DOWN
Nov 02, 2009 | Akai PT50DL24 Television
PS3 Quit
Alot of the playstation 3 systems are having problems overheating. this would be the cause of the system shutting off. not to much u can do unless u know how to replace the fan or if you bought the warranty. other then that you would have to take it to get fixed or buy a new one. hope this helps sorry if it dont
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
Intermittent lamp turn off
I was told by the repair service to unplug the power cord for about 5min. This resets the internal computer. I think this helps but does not cure the cause. Good luck.
May 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY GRAND WEGA
I have a KDF60XS955. When I power it on, the fan comes on, the standby light flashes green several times, the lamp comes on and the standby light goes to solid green. This lasts for less than 5 seconds then the lamp goes out, followed by ~30 green standby flashes, the lamp coming on with the solid green standby light for about 5 seconds then shuts off the lamp again. I can hear/feel the fan running the enitre time. This cycle continues endlessly. Please help!
May 20, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a Mitsubishi 55 inch rear projection tv model ws55859. As soon as you turn on the power, the tv shuts down (either by remote or front of panel). The green light comes on for about 1 second and you...
Have you tried holding the input and menu buttons on the set both in together for 8 seconds to see if it will blink a 2 digit error code? Try that and let me know what code if any flashes from the Led.
Mar 30, 2008 | Televison & Video
Computers & Internet Logo
David Payne
David Payne
