Question about Philips HDD082 MP3 Player
Stuck at start device manager
I tried solution provided here, the screen shows start device manager, and window can detect the device, but when try format, it says cant complete. and i try to use device manager to repair, it says ur device is not connected. pls help...
  • 8,596 Answers
Go to the faq on the Philips website for the SA6087 - My GoGear is not recognized by PC.
Posted on Feb 11, 2008
Alienware M14x stuck on windows starting scren, the video card driver seems to have been disabled
Try going in to Safe mode. This loads the basic drivers and if you have a problem with hardware, it will still open up Windows.
Turn on computer and immediately press F8.
Any hardware issues will show up in device manager.
Mar 22, 2014 | Dell Alienware M14x Notebook
My GO gear Mp3 player wont be detected on any computer. even if you install the hardware, it wont still detect.
if your player don't detect . also don't detect with Philips Device Manager
try to download this driver for it usb 2.0 ADFU Driver .
i worked with 7 and in system device manager show "uknown usb device" but in XP show this "usb 2.0 ADFU Drive" and also the Xp itself install it . if your windows dosent have this so go on to download it manualy . then use philips device manager to repair it . i do it myself and it worked
Dec 13, 2010 | Philips GOGEAR SA6045 MP3 Player
Just reinstalled windows xp and now my creative labs soundblaster live! audio card is not detected. did all the troubleshooting in the hardware manager and it says the the device is working properly. did...
You could have a ghost device in the system. Remove the card and start the computer in safe mode. Look at the device manager to see if there are any sound devices detected. If so, delete them. Now install the card and let Windows detect it. You probably left the card in the machine when reinstalling the O/S. You shouldn't have any peripheral devices hooked up when doing a reinstall of Windows XP.
Sep 26, 2010 | Creative Labs Sound Blaster Live! 5.1...
Can't actually start it up on messenger
Try to check under device manager if the webcam attached is detected. To view device manager:
right click on My computer > Manage > Device Manager. Verify if the webcam is detected. if you found error then try to update driver using cd driver.
thanks!
May 22, 2010 | Microsoft LifeCam VX-3000 Web Camera
My Red Sansa Clip 4GB will not show on any computer i plug it into, It only charges and i have tried the auto detect, mtp, and msc settings. Any Suggestions?
See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix.
Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61
Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware
NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit
May 17, 2010 | SanDisk Sansa Clip MP3 Player
CdRom drive not showing up on computer. CdRom works when push button but nothing comes up nor shows up in MY COMPUTER.
Check if the CD ROM is being detected in BIOS setup or not? In case it is not detected in BIOS, then make sure that all the cables that connect the ROM to the mainboard are okay. They should not be loose or broken. You may also try replacing the cables.
In case BIOS detects it but windows is unable to detect it, check in Device Manager to see for any disabled or unknown devices. To enter device manager, click on Start >> select RUN and type "devmgmt.msc" without the quotes and press Ok. Enable back the device from there and then check.
Aug 10, 2009 | Office Equipment & Supplies
Brother DCP165c Driver installation Problem
I would boot in safemode (hold down f8 immediately when it starts (when it says Starting Windows xp), then delete all printers (associated with this) in device manager.
remove any printer software as well (add remove programs or start programs (printer program name, remove software IF listed),
also remove the port you are using in device manager be it lpt or usb. if the drivers siuggests installking without it connected do so, otherwise, just restart and it shoudl start installking the hardware amnd software it finds. be sure you have the correct drivers ready as well>
Good Luck
Jul 09, 2009 | Office Equipment & Supplies
Sony walkman mp3 nwz-b135f not showing as a device on my computer
Please dont use any of the solutions above
try this..
If the Sony Walkman Mp3 is not detected as a drive in windows explorer but shows as a portable device in Device manager,, do the following
right Click My Computer > Manage
Select Device manager
right click Walkman , which will be under Windows Portable devices
Click Update driver
Select no, not this time, click next
Select Install from a specific list... ( Advanced) and click Next
select don search ,....
Click Next
Put a check mark in Show compatible ...
Select USB Mass storage device and click next
Conitnue and the device will be detected as a drive in windows explorer
amisadath@gmail.com
Jul 02, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
Philips HDD082 MP3 Player Logo
48 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
