Printing initiation is very slow.
I have 2 hard disk where I made 2 partition. One was FAT32 (20GB) and another was NTFS (320GB) Both of them are equipped with Windows XP. The problem is when I wish to print something using the NTFS drive, it takes about 5 minutes for printing to initiate which is so slow. But the problem doesn't occur if I use the FAT32 drive where I can print immediately. I have identified that it's not lack of disk space. Can anyone PLEASE give me the solution?
  • 4 more comments
  • ahmadzx Apr 14, 2009
    Yes, the printer spooler was set to automatic. Is there anything wrong?
    Drivers? Well both of my hard drives use Windows XP Professional Version 2002 Service Pack 2. Both of them prints on Canon Pixma MP145 All in One.
    I got 2 XP on one computer because the FAT32 one has lots of office works and backups while NTFS one has a lot of graphic, multimedia and games. Yes I use both of them regularl.
    I get to choose 2 OS upon startup it look like this before Windows Startup:-
    Microsoft Windows XP Professional <-- The NTFS
    Microsoft Windows XP Professional <-- The FAT32
    Microsoft Windows <-- The FAT32 using Windows ME
    Please be informed that I use 2 HARD DISK in one PC and not the partition. It can be either the NTFS or FAT32 that shows Healthy(Boot).
  • Randall  Trahan
    Randall Trahan May 11, 2010
    The optimum situation is to be able to use Print Spooler separately for each version of Windows you have. Right now you are sharing print spooler so that's why it takes so long. But seems like if you installed Windows XP twice, then you would have separate spoolers...??
  • Randall  Trahan
    No its what it is supposed to be. Do one more thing I want to know what the active partition is; that's the partition Windows uses to boot up. If its the 20GB, then it has access to resources first. Do same thing, start>control panel>admin tools>Computer Management>Disk Management.
    Look at the writing in each of the partitions and tell me which one says boot, active....
  • Randall  Trahan
    Check the print spooler application first and make sure it is set to automatic. Click start>control panel>admin tools>Services>then scroll down to print spooler. You can right click on it if it is not on automatic.
  • 432 Answers
What drivers are you using on each partition - what version of xp is on each partition and if you restart the print spooler on both of them does that help ?
Also why have you got 2 installations of xp on one computer using 2 filing systems ?
Posted on Apr 14, 2009
WD elements 320 GB not visible physically fine
Right-click on "My Computer"
Click "Manage"
Double-click "Disk Management"
You will probably see Disk 0 and Disk 1 for your primary hard drive.
Go to lower right portion of box and scroll down until you see Disk 2. It is probably your USB drive without a letter. It should show the size of the drive.
Right-click in the left portion of that drive box (Disk 2)
Click "Initialize" and "OK" in the next dialog box. This takes just a few seconds and it should now say "Online" in the "Disk 2" box.
Right-click in the box to the right side of the "Disk 2" box (where it shows your disk drive size and says "Unallocated".
Click "New Partition" and a "New Partition Wizard" will open up.
Click "Next", then select "Primary Partition" and click "Next".
Verify partition size (use entire disk size available unless you are creating multiple drives) and Click "Next".
Assign drive letter ("F" is typical if CD-Rom is E) and click "Next".
Format this partition with "NTFS", "Default", "New Volume" and click "Next".
Then click "Finish" to exit the wizard and start formatting.
Be patient... this can take awhile (it took just over an hour for a 320GB drive).
When done, you should see an icon for your drive in Windows Explorer!
hope this helps
Jul 29, 2012 | Western Digital Elements powered by WD 320...
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
Hi my toshiba mk3265gsx hard disk is detect as a usb device as external, but not work and has no partition no bad disk and can not be able to work with this, it is just a usb device with no action (this...
With a brand new drive, you have to initiate your drive using the Disk Management tool in Windows.
To do this, go to Start-->Control Panel --> Administrative Tools --> Computer Management. Then select Disk Management from the menu on the left. Once everything is loaded up, you should see your new drive in the list of volumes on your computer. You'll have to right click on it and click Initialize Disk. Once you've initialized it, you'll have to formate the drive and create partitions.
If you need anymore help, let me know.
Mar 25, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Hi, I had problem using Imation 27390 apollo expert ux. The hardisk is in NTFS format, and work perfectly fine when i plug in computer with Windows Vista and 7. But it cannot be recognized by computer...
Windows XP has limitations on recognising too large NTFS disks. One of the solutions would be to format the entire disk as FAT32 or make a partition and format that as FAT32.
Feb 28, 2011 | Imation 27390 Apollo Expert UX 2.5" 320GB...
I want to format my 2 T hard drive from NTSF to fat 32 , how to do please help
Ok this fix will erase all Partitions on the drive, Make sure you have all data back'd up.
Open Command:
Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator. Or Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
You should have a black MS-DOS prompt on your screen. Type DISKPART in and press enter. Another window will open
Type: list disk It will the display list of devices with memory storage. Find your disk, It should be in a Table(kinda). You have to locate it by its size. so look for 1TB(1000GB) In this Example its Disk 2, yours may differ.
type in: Select disk 2
Execute the rest one by one: CLEAN CREATE PARTITION PRIMARY SELECT PARTITION 1 FORMAT FS=FAT32 ASSIGN EXIT
Wait for one command to complete before running another
You should be left with a working FAT32 Device :P
Regardz Sinn3D
Oct 27, 2010 | Western Digital My Book Essential 1TB...
How can i partition my 320gb sea gate ext harddisk
you can partition your hard disk while installing windows xp
and if you want to parition your hard disk after installing your windows,you will need third party softwares called parition magic which are free to try,but you will have to buy those softwares to use it,so its better to paritiyion your hard disk while installing windows
Jul 22, 2010 | Seagate 320GB FreeAgent Pro FireWire 400,...
Aspire 6930 has 320 GB harddisk,i faced some problem with Avasti Antivirus n i formatted the system to run my system smoothly, but now the problem is harddisk is showing only 128 GB. that too the partition...
You can Reformat the system and REMOVE all partitions. Windows setup will create a new partition from available drive space. If you need to save your data,You can also use a utility like partition Magic and resize the partition. There is a trial version available at no charge. just google "partition magic"
Aug 05, 2009 | Acer Aspire 6930-6771 Laptop
When I try to back up my computer files for Windows Vista using a Toshiba 320GB capacity portable external hard drive I receive the message that I need a ntfs drive. Can my external drive be converted to...
Yes, it can:
Before you begin, connect your external hard drive.
To format the drive with NTFS
1.
Log on to your computer as an administrator.
2.
Click on the Vista Orb right-click Computer, and then click Manage.
3.
Under Storage, click Disk Management.
4.
If the Initialize and Convert Disk Wizard appears, click Next. If the wizard does not appear, skip to step 8.
3e609ff.gif 5.
On the Select Disks to Initialize page, click Next.
84b8e54.gif 6.
On the Select Disks to Convert page, click Next.
330a86a.gif 7.
On the Completing the Initialize and Convert Disk Wizard page, click Finish.
a63fbd2.gif 8.
Right-click your external drive (which will probably be drive E or drive F), and then click Format.
f8f5f91.gif 9.
In the Format dialog box, type a name for your external hard drive, such as Backup Drive. Then, click OK.
7560a25.gif 10.
Click OK again.
0a517a9.gif Windows XP formats your external hard drive. Within a few minutes, your drive will be ready for you to use.
Jul 17, 2008 | Toshiba Computers & Internet
Not found
Right-click My Computer, choose Manage, then click on Disk Management. If you are prompted about Initialize and Convert, you don't need to Convert, but you DO need to Initialize the disk.
Once the disk is initialized the OS can use it, but you will still need to create a partition and format it. Find the next disk in the list on the bottom right and right-click the box (it'll say Disk 1 or something like that) and choose New Partition or New Volume to create a new partition or volume -- partitions are for Basic disks, volumes are for Dynamic disks - usually I use Basic disk.
Hit F1 while in Disk Management for more help.
Apr 11, 2008 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
