Question about Sony Xplod XM-554ZR Car Audio Amplifier
Power Protection Light Will Not Switch Back to Green
I have a Sony XM-554ZR Xplod 600 Watt 4-channel amplifier running two subs and a set of 6 x 9s. I went to tune the amp the other day and everything was working just fine but as I began to tune it the power protection light turned to red and will not turn back to green. I have checked the fuses in the amp, the interior of the car, and in the battery, but they were all fine. I even unwired the amps inputs and rewired them again, as well as readjusted the ground but still the same problem. Do you know what I could do to get the light to switch back to green?
    President:
  • Sony Master
  • 1,114 Answers
Disconnect all speakers, then turn the amp on. If there is no internal problem with the amp, it will go green. If it does go green, reconnect your speakers one at a time with the amp off then turn it on. when you connect the speaker that's causing the problem, the amp will go into protection. At this point, it's one of two things, a bad speaker wire (screw thru it or touching another terminal) or a bad speaker(burnt voice coil) to test that wire, disconnect the wire at the speaker and turn on the amp, if it's still green, all's well in the wire department. Meter the speaker with a multimeter on resistance, if it's blown the meter will read 1.... If you don't have a meter, connect the speaker that's having the problem to the other channel and test again, if it goes into protection, you've got your answer. Bad speaker. Hope this helps
Posted on Jun 14, 2009
Have two front ,two rear speakers, and two tens that i want to hook to my stereo. How do i do it and get the maximum sound?
If the Sony amp (I'm not familiar with that one) has its own crossover and subwoofer output, use that, and set your crossover point for what sounds best to you. Honestly, it is best to have a SEPARATE two-channel amplifier & crossover for the 10" subs. Whatever you do, make sure you use a large capacitor (2 Farad or more) at the power input of the amplifier for the subs. This will help prevent blown fuses. (It is also a good idea to use at least a 1 Farad capacitor at the power input of the amplifier for the other four speakers.)
May 11, 2015 | Sony XPLOD XM-554ZR 600 WATT AMP XM554ZRRB
Is the sony xplod cdx-gt71w able to support a subwoofer without another amp
Sure is.
The sony is bridgable as follows:
  • 100W x 4 @ 4 Ohm
  • 100W x 2 + 250W x 1 @ at 4 Ohm
  • This will allow 2 channels to run 100 watts each @ 4ohms with an additional single channel with 250 watts @ 4 ohms.
    The single sub channel is created by bridging channels 3 & 4
    Dec 22, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
    My 600w power amp XM-554ZR wont turn on.Its an Xplod 4/3 channel, and it was working fine...until yesterday that i checked it. the green light was off.
    open it n there is a red wire look at the end of it n u would see a black celinder with a with a white strip on it change that part if it is burn
    Jul 14, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    How to put 2 subs on a Sony XM 554ZR bridged
    Unless it is a 4 channel then you will have to run them in series. Keep in mind that you will only have mono sound.
    Jul 07, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    I have a Xplod XM-554ZR Car Amp and the green light is blinking it worked just befor and now i have no sound
    The amp is in protection. Disconnect any speaker from it, then turn it back on, if it's not flashing, check your speakers with a meter and check speaker wires for shorts. If it's still flashing, you've blown the protection circuit and it needs to be replaced or repaired. Hope this helps
    Jun 11, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont...
    sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
    Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Red light
    something is shorted in the circuit, or your subs. unhook the subs first and try it again, if it is still in protect then it is most likely the output transistors.
    Feb 22, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
    Sony xplod xm-554zr amp
    try disconecting ur battary for 2 min and try it again
    Jan 18, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
    Car amps
    important is to hav correct wires and groud cable...
    Dec 29, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
    Sony Xplod XM-554ZR Car Audio Amplifier Logo
    407 people viewed this question
    Top Sony Car Audio & Video Experts
    xxxxxx xxx
    Larry Stiles
    Larry Stiles
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
