FixYa.com
Tags:
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Drain pump and no water going in
posted by cboinsincity on Sep 13, 2007
the drain pump sounds like it is continually running and water does not go into the dishwasher.
thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 13, 2007
FixYa! (100)
dovi
Rank:Guru Guru
Rating: 88%, 2067 votes
It sound as a water level switch issue.The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the service panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube.
In case it doesn't react, you should replace it.
Good luck !
Rating Locked! (?) cboinsincity has rated this solution as FixYa!
Solution #2
posted on Apr 20, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This most likely is not a level switch problem. Take the kick plate off (after turning circuit breaker OFF), look down in the base off the dw and youll probably see some water. Use a wet vac or towel to remove all water. The drain pump will now shut off and unit should function normally. You can now run the dw with the kick plate off and using a flashlight look for leaks. The bosch dw has a float switch in the base, water will activate this switch which will shut off the water valve and only allow the drain pump to run....it thinks it has a leak!
Make sure the disposal is draining properly & drain hose is not kinked as these are the most common reasons for your problem.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Dishwashers problems?
Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
extnd cycle time
has been working fine for yrs,... Answer This...
Bosch dishwasher model...
Sometimes water is not let in... Answer This...
bosch dishwashers
I have 2 in my kitchen. 10... Answer This...
dishwasher
soap not dissolving, dishes not... Answer This...
SHU66C02 Front Panel Switch...
My wife pushed the... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
