Question about Refrigerators
Compressor will kick on and off after 30-45 secs and repeat over and over , and smell hot rubber. The refrigerator will not get cold Any ideas ? I think it might be a relay switch
  • 242 Answers
It most likely is the relay on the compressor , they will go out if the unit short cycles , it is worth replacing this part , easy and not expensive , sometimes when this happens the compressor locks up and the new part will do the same exact thing , this means you need a new compressor.
Let me know if you have any other questions.
Phil
Posted on Apr 14, 2009
Samsung fridge SR-L628EV, compressor works, all fans works but no cold air at all, it has been setting for two years but now is not giving cold air, any idea on how to fix it? Thank you
either needs freon [compressor will come on if low freon ] interior fan ,compressor internal valve damage tx valve damage condenser fan -etc can be anything with compressor running feel and look at condenser coils they should be hot and be careful of fan if not hot more than likely need freon
Sep 04, 2016 | Refrigerators
Maytag fridge wont get cold kicks on and off
If your model is the MZD2766GES it would be a good idea to examine the=> 12002794 Relay and Overload Kit
replacing the=> 65889-4 Run Capacitor
will also be recommended. Can yu feel the top of the compressor? Is it hot? I am here if you have questions, Sea Breeze
Jan 15, 2013 | Maytag MZD2766GES Side by Side...
I have a kenmore elite , Mod# 71203100 mfg=10/10/2001 it worked fine since I got it ..48 hrs ago it was found to be not cooling anymore, lights go on fan's work , but compresor will kick in for 30 sec and...
I would fix it because The way I am understanding the compressor is getting hot and thermally kicking out. This could be a thermostat or a start relay for the compressor. Or it could be low on charge that will also make the compressor shut down because of the head pressure. I would check out my thermostat really close and any start relay's for the compressor. It would be about 200.00 compared to 1200.00 to replace it.
Jun 30, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Ac blowing hot and cold, steering wheel vibrates when ac is on an
sounds like the ac compresser is going bad. use a shorter belt to bypass the ac compresser to see if that stops the vibration
Apr 12, 2010 | 1997 Toyota Tercel
Compressor making noise and freezer is kicking cold air out but
Sounds like the start relay, start capacitor and overload have become defective. Turn it off to prevent further damage to the compressor internal overload. Check to make sure the condenser fan and the evaporator fans are running and get back with me with an answer yes or no. Thanks, Sea Breeze
If the model number you have above your post are correct I will also send you part numbers and hot to replace.
Aug 04, 2009 | Maytag PTB2154G Top Freezer Refrigerator
Compressor runs for 5 sec then stops
If it starts & stops frequently and you don't have a hot or cold tube at the compressor, you need it recharged. Check around for service. It costs between $150-$200 in my area.
Feb 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer not freezing and burning smell
it may be the compressor overheating it could be the relay but if the compressor is hot then you are low on freon and need to have it recharged
Jan 26, 2009 | Amana ARS2464B Side by Side Refrigerator
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
Beverage Air ST58N Not cooling
Compressor is cycling on the overload protector. Cause could be a bad starting relay but is more than likely the compressor is bad.
Jun 11, 2008 | Carrier ST58N
Refrigerator burning rubber smell when it tries to turn on
sounds like the relay on the compressors is getting hot and cutting the unit out, if the fridge is quite old it may well be the run windings gone short circuit in the compressor pot. The relay switches from start to run windings so may be firing the start circuit, switching over to a shorted run winding, and then getting hot and activating the thermal cutout and hence the burnig smell, plus the start and rapid shut down of the compressor.
Mar 19, 2008 | Refrigerators
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
