Question about Trilogy Alarm Lock T2 TRILOGY® Digital Locks DL2700
Changed factory code once and need to change it again
Changed the factory code to new code but it needs to be changed again due to a terminated employee.
    Problem Solver:
  • 12 Answers
I really need the model no. of your lock to be sure I give you the right info, but you can go to www.alarmlock.com and click on "support" at top of home page, then scroll down to bottom of support page and click on "technical library". On the next page, scroll down to DL Programming Manuals and click on your model number. Tip: in the programming instructions, when they refer to the "A" or the "AL" key it is located where the # key is on a phone keypad (to the right of 0).
This key has the alarm lock logo on it. Hope this helps!
Posted on May 18, 2009
My old thermostat has 8 wires and I'm trying to figure out how to install a Honeywell Rth2310b thermostat.
The terminals on the old stat should be basically the same as on the new stat...with a couple exceptions anyway. Note the color of wire on each terminal before removing them and reconnect to the new stat on the same terminals. 8 wires typically indicate a heat pump, so in the configuration menu you'll have to tell it whether to energize the O terminal in cool or not. If you have individual wires on Rc and Rh terminals, you must remove the factory jumper between those two terminals on the new stat. If not, you'll burn out one of the two control transformers or possibly damage your new stat.
In the configuration menu, you'll have to tell it whether its a gas furnace or electric furnace, select the way the fan operates and possibly limit the cycles per hour on both heat and cool modes. There's a lot of subtle entries that need to be done to 'tailor' the new stat to your likings also.
I think it would be best to rely on someone thats a bit familiar with HVAC to change out your stat for you..... as once it is changed, all possible functions of the stat need to be verified as correct in operation.
Feb 07, 2015 | Honeywell CT3200 5-2 Day Electronic...
Code change on a 1996 Mercury Grand marquis
Sorry,but the factory code always works.Ford may be able to change it,though. don-ohio
Dec 27, 2011 | 1996 Mercury Grand Marquis
Reset or change door panel code for lincoln navigator 2005. i forget my password code to open the doors.
You cannot change the factory code and you will need it to set a personal code. To find the factory code you will need to open the fuse cover on the passenger side of the vehicle under the instrument panel. Above and to the left you should see a module that has a label/sticker on it with bold numbers (5 of them). Below is a picture of an exemple of the location of the module and how the label looks you may need a flash light. It is down there believe me. Once you have found the code, tried it and am sure you have the right code you can set a personal code, one that you can remember easily. to do this enter the 5 digit factory code. Then within 5 seconds press the 1/2 button. Now enter the new code you want to put in. Once the new code is put in the locks will cycle confirming to you that the new code is put in there. This does not replace the factory code and both codes will work. If you ever want to erace the personal code, press in the factory code and within 5 seconds press and release the 1/2 button within 5 seconds and the personal code will then be removed. I hope this helps you and good luck.
May 28, 2011 | 2005 Lincoln Navigator
Music player is not working.it's library is updating continuously.once library updated then it again gets update.
Since the music library keeps updating itself, and the music player is still not working, then you need to factory reset the phone. Scroll throug:
menu > settings > restore factory settings
select 'restore factory settings' you would be prompted for security code enter 12345, which is your default. (Unless you had initially changed it, whereby you would have to enter your new code). Then the phone would be as good as newly purchsed, internally.
Take note that reseting your phone wioes off all the data on the phones memory, so ensure to transfer them to the memory card, and back up your phone contacts. Your sim contacts would be intact.
Hope that helped.
Success.
May 12, 2011 | Nokia 3110 Cellular Phone
I have gotten and hdtv from a friend and when I turn tv on it says I need a pin number to enter. I can not get a hold of them to get pin. Is there anyway I can override this in the settings program?
The Factory code number is 0 0 0 0 If the code has been changed, You can select to reset it using the Setup Code either under the channel blocking or setup code section.
Once there, Press 0 7 1 1
You will be given a message "INCORRECT ACCESS CODE" Press 0 7 1 1 on the remote again
Next, "enter your new access code" shows on screen.
Now you can enter a new 4 digit code. (write it down somewhere)
Dec 03, 2010 | Philips Televison & Video
We have a Kenmore gas dryer model #76832500. The ignitor glows and the gas will light for a short period of time and then go out. Once the dryer cools down it will light again. Our manual shows there...
The 3 pin coil is your booster and holding coil and it ignites the 2 pin secondary coil. Is the flame blue or yellow? I would change both. Coils are a lot cheaper than the whole gas valve assembly.
Make sure to check the dryer's airflow. If the dryer is ducted, pull the machine away from the duct and try starting it again. Does the dryer have some sort of electronic control which is sensing an error and terminating the heating circuit? If there is it would be a box type thing located near the gas valve and it would have lights flashing on it. If that's the case, it's a new problem in itself as you would need an error code listing to begin looking.
Assuming air flow is good and gas supply pressure hasn't dropped (also check that gas inlet hose is kink free) and it is the coils that are failing, change both and fix your problem
Aug 29, 2010 | Kenmore Dryers
No factory wire connected to the neutral terminal
it might have something to do with the new N.E.C. that new dryers need to have a 4 wire cord installed on them instead of the old 3 wire since the code change some areas require 2 hot leads/1 neutral lead/and 1 safety ground lead, before this change as long as the feeder came directly from the main panel a 3 wire cord was acceptable,check with your appl dealer,they may omit this until you wire it to protect their liability
Aug 14, 2009 | Danby DCD5505W Electric Dryer
Hi .my nokia 6220 switches itself off after the battery has been fully charged .once its switched on again it works okay
It may be due to power surge happening when you remove your charger from phone.
1.Try changing your power adapter
2. Switch off the power adapter first before removing the charger connection from your phone.
3. Remove the battery and clean the copper terminals with a cloth
4. If none of these idea works, then give a try my restoring your mobile to factory settings.
Aug 09, 2009 | Nokia 6220 Cellular Phone
I need help I changed the key door code on my 1996 Lincoln
1. Enter the original factory code, 2. within 5 seconds, press1/2 3. within 5 seconds enter your chosen new 5 digit code, pressing each digit within 5 seconds of the previous. 4. all of the doors will lock and then unlock to confirm programming of the new code. you can now use either factory or this new code. 6. To erase all of the personal entry codes and remote transmitters programmed - 1. Enter the factory code 2. press 1/2 within 5 seconds 3. press and hold 1/2 for two seconds
May 08, 2009 | 1996 Lincoln Town Car
Region Selection
You cannot change the region code again after 5 times of changing even if you move it to a new computer or install a new OS on your computer, I recommend buying a new DVD Drive to access full functionability and no restrictions.
Jan 12, 2009 | Hitachi LG GSA-4120 DVD+-RW/RAM 12x Burner...
Trilogy Alarm Lock T2 TRILOGY® Digital Locks DL2700 Logo
471 people viewed this question
Top Trilogy Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
