Question about Maytag Neptune MDG5500AW Gas Dryer
Neptune Dryer Just Stopped
I have a Maytag Neptune Dryer, model MDG5500AWW. I just heard the beeping sound when it is ready to shut off, went in the laundry room and found the dryer not spinning and a faint smell. All the lights ontop light up normally but the drum isn't turning. It spins freely. Any suggestions? Also, if it is the belt, do I just remove the screws in the front inside the door to check things? I bought this as a floor model and it came with no manual.
  • Murphy Taylor Apr 14, 2009
    Thanks for the quick response. This sounds crazy, but once my husband pulled out the lint filter and put it back in, the dryer worked fine. I had some socks and a pair of tennis shoes in there and I wondered if the shoes hit the filter and lifted it somehow just enough to affect the dryer. I will download these manuals so I have them for the future. Thank you for the quick response and help. I really appreciate it.
  • 4 Answers
The user manual can be found here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/2206682B_MD55.PDF
The service manual can be found here: http://www.servicematters.com/maytag_library/docs/16023110.pdf
It does sound like the belt.  Refer to the service manual above on installing a new belt or troubleshooting for other issues.
Posted on Apr 14, 2009
I have a MDG5500AWW Maytag Dryer. Everything works fine but when it's sitting and off, no lights lit, it beeps 3 times every 10 minutes or so. Never timed it, could be less than 10 minutes. I usually...
Sounds like a prompt of some type...waiting for an input like to 'open the door' at end of cycle. Not sure myself but do believe the answere is in the customer service manual you received with the new machine. If you do not have one, go on line to get one.
Oct 17, 2013 | Maytag Neptune MDG5500AW Gas Dryer
Where can I guy door switch kit for maytag dryer MDG5500AWW
most any maytag/whirlpool dealers, or any appliance parts outlet,its a very common part and with your model # they will be able to get you one
Mar 07, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Where can I buy a replacement belt for my Maytag Neptune MDG5500AWW dryer?
Nearly every appliance store and appliance repair shop sells replacement belts. Your area Sears / kMart retail store will have them, too. Many hardware stores sell them as well.
if you don't mind waiting, you can find them online, too. Here's a list of places that Google found for Maytag Belts. You should use a combination of Maytag dryer model number and the number that appears on the belt to obtain a replacement.
Oct 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
We own a Maytag Neptune Dryer Model No. MDG5500AWW and have already replaced the mother board. The dryer began beeping periodically and then it just won't start - controls are frozen but they do light up....
If you hear random beeping and a double beep sound when you are pressing a key it means that your problem is the keypad itself, not the board. The keypad on this model is the entire console (not a cheap part @ $200 but this was a very well built dryer so probably worth the repair). You most likely have one of the keys that is shorted out on the console that is causing all of your troubles.
Get yourself a new key-panel part number 33002536 and replace it and you should have your problems solved.
Good luck and please let me know if you have any other questions on this!!
Aug 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag mdg5500aww gas dryer sensor
First of all shut off the power by pulling out the plug.
If you are sure of the sensor issue then you need to remove four screws on the inside of the door. Two screws are located on the left and two on the right, look at the hinge and you will find two. The door will lift out when you remove the screws. When the screws are out of the front, the front panel can be remove by pulling on the outside surface.
Aug 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas will not stay lit.
sounds like a bad coil
they are on top of the gas valve
Jul 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer model # mdg5500aww sensor not working is just starts a 37 minutes
How do I lift the top panel of my Maytag Neptune dryer model MDG5500AWW?
Jan 13, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
419 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
