Question about Sharp Multi-System Mini Component System Shelf System
CD 3 DISC PLAYER MODEL ES222E
DISC CHANGER STOPPED PLAYING!,FOUND IT WOULD NOT EJECT,TOOK APART &GOT CD`s OUT,NOW IT SEEM`S THAT NOTHING WORK`S,NEED SOME HELP IN HOW TO FIX?THE DISC TABLE WONT LINE UP &HIT`S OUTER CASING,NOT SURE BUT THINK WHERE DISC SPOSE TO TURN IS NOT TURNING FAST ENOUGH?IS IT WORTH TRYING TO FIX OR NOT?CAN SOMEONE PLEASE HELP US,ON A PENSION &CAN`T AFORD TO BUY NEW ONE &NOW HAVE NO MUSIC!
  • Anonymous Nov 14, 2007
    when i try to play a cd it sounds like it will not spin fast enough and will only play a few songs then quit all toghether
    New Friend:
  • 26 Answers
First place to troubleshoot for the above listed issues are the gears, if gear driven spindle, or the belt if it is belt driven. If gear driven spindle apply enough non-attractive lubricant to the gears so they function freely. If belt driven clean all surfaces that the belt touches to ensure all dust or debris is removed and then lubricate center spindle posts only so that they can rotate freely and with as little friction as possible.
Posted on Aug 28, 2017
SOURCE:
  • 82 Answers
SOURCE: CD Player not working
Since the unit was in storage for a while dust may have settled on the lens.Try cleaning the lens.
Posted on Mar 22, 2008
  • 82 Answers
SOURCE: Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Posted on Mar 29, 2008
SOURCE: CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
Posted on Apr 09, 2008
  • 117 Answers
SOURCE: The CD player will not play. It worked yesterday
Please open the lnik of your computerhttp://support.microsoft.com/kb/314060 and run microsoft fix it.
after that restart the computer, hopefully it will work.
Posted on Oct 23, 2009
SOURCE: The 3-Disc Rotary Changer will not eject. Error ER-CD11 appears.
notice sharp 3 disc rotary changer en français; svp
Posted on Nov 26, 2010
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
6 disk CD changer in 2004 Chevy Suburban
I am having the same problem with my CD changer in a 2004 Suburban. Have you found a solution yet? Chevy dealership told me that I would have to replace the radio.
Dec 31, 2009 | 2004 Chevrolet Suburban
Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Dec 11, 2009 | Car Audio & Video
Car cd changer problem
cd changer not working in leganza
Jun 18, 2009 | USA Spec SCD-D50 6-Disc CD Changer
CD Changer not reading CDs
2000 bmw 528i,my cd changer also reads no cds,this seem to be a common problem with all bmw cd changer.Anyway i removed the cd changer from my car,took the outside black cover apart only to see that a white big wheel came of its place,(its the wheel that holds the cd in place from the top (bottom wheel is black attached directly to the motor,as the cd is sandwitched between the black,and white wheels) .if that wheel is out of place the cd will not turn inside the changer for the eye to read it,so your radio screen will read NO CD OR NO DISC.Very easy fix,just place the wheel in its place,and everything worked fine,it took me 20 minutes to fix.
p.s :
1- you do need to make sure you have an original cd in for testing it.
2- you do not need to recode your cd changer at the dealer if you have an old bmw,dealer will need to recode cd changers for 2006 and up.
Good luck.
Jun 15, 2009 | 2001 BMW 3 Series
Six cd changer with 6 cds stuck inside, none will play and message appears no cd, or cd error,or eject error in a 2004 ford escape
Ok this may seem barbaric but it worked on mine.......Hit the top of the stereo a couple of times and see if it corrects the problem.
May 30, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Rockford Fosgate cd changer
I have the same problem with the 2006 sentra
May 28, 2009 | 2005 Nissan Sentra
Jammed CD & Magazine in an Alpine CHA-S634
Mine jammed after I dropped it, trying to swap it into a new car :-)
Same problem, however. Three of the six CD trays had wandered into the righthand mechanism (which selects and plays one cd at a time). Nothing else at all, most fortunately, was broken.
I removed the cover (3 screws on each side), and the small black faceplate that holds the eject button. The main faceplate came off too, needless to say; no screws, just tabs.
You have to remove the side brackets also, and the angle-adjust spring loaded pins on both sides need to be slid out. Then the body of the cd changer rotates out of its cover.
Now, you can see down into the mechanism. A CD was still stuck in the reader, along with several shifted trays. I could simply remove the CD, and with a small screwdriver, shifted the trays back over so that I could then successfully eject it. I removed and realigned the trays, which had been jammed, and it worked once more! Reassembled and reinstalled ;-)
Apr 26, 2009 | Alpine CHAS-634 6-Disc CD Changer
Changer refuses to eject or play CDs, keeps saying reset
Hello, in order to repair CD changer you have to be equiped with special tools and knowledge. This repair is only possibble in Authorized Sony Service or at the shop with best references for this kind of job. Best regards, Arpi
Apr 13, 2007 | Sony CDX-656 10-Disc CD Changer
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Sharp Multi-System Mini Component System Shelf System Logo
101 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
