Question about Intel 845GE Motherboard
USB 2 DRIVERS ARE NOT LOADED FROM ORIGNAL INTEL EXPRESS INSTALLER C.D. AFTER BOOTING THE MACHINE FROM BOOTABLE C.D. INDICATOR INSTALLATION FAILED FOR USB 2 OTHER DRIVERS FROM EXTERNAL SOURCES LIKE BLUETOOTH ARE ALSO NOT LOADED
    Problem Solver:
  • 22 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
qpoii12
Posted on Sep 08, 2009
Intel DQ965GF Motherboard won't load WIN OS (WINXPPro volume disk or Win7) tho an old Dell disk did load. Is there a fix? Thz
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+965+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DQ965GF
Windows 7 is not a supported system, but you can use the drivers from the vista system, but only the 32 bit.
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
After the post, BIOS will attempt to boot from the first device listed in the boot order.You need to change that, so the first boot device in the list is the dvd drive. If that device is not bootable, BIOS will attempt to boot from the second device listed, and so on.
Note: The boot order is a BIOS setting so it's OS independent. In other words, it doesn't matter if you have Windows 7, Windows Vista, Windows XP, Linux, or any other PC operating system on your hard drive or other bootable device, these boot sequence change instructions will still apply.
Here is how you do this:
http://www.hiren.info/pages/bios-boot-cdrom
But ofcourse there could be a problem with the dvd drive or harddrive.
To install windows 7, you will need at least 1 gb ram or more, and a dual core cpu.
Best of luck
Feb 12, 2013 | Computers & Internet
How do i fix it?
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 02, 2012 | E-Machines eMachines Desktop PC
The motehrboard bios doesnt boot from usb to install windows, how can i update the bios to boot from the usb?
Insert your USB jump drive into a USB port on the computer containing the bootable program. Copy the information to your jump drive, then insert the drive into a USB port on the computer you wish to boot the program from.
Power on the computer. When the computer begins displaying its startup information, hit the key indicated on screen to enter the computer's BIOS (the "F1" or "Delete" keys are commonly used to access the BIOS).
Browse through the menu options in the BIOS to locate the computer's startup and booting options to locate the "CMOS" menu, which is where you'll have the option to set which devices will boot at startup.
Browse though the list of bootable option---they'll be ordered as "First Boot Device," "Second Boot Device" and so on. Set the USB jump drive as the first bootable option---your BIOS may refer to the drive as a "USB Removable Floppy Disk."
Save and exit the BIOS. When your computer restarts, your program will boot first before your operating system.
Feb 17, 2011 | Intel QDI P2PE/800 Pro 82845PE Socket 478...
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
I keep getting this error: Intel® Express Installer < The application failed to initialize successfully-(E0441203). Actually when installing the mother board drivers, there has been a power cut...
The failed install has messed Windows itself its integrated installer has been corrupted.
The easiest way to fix that is to reinstall, otherwise you will gonna have to manually delete all partially installed drivers, clean the registry and perform a Repair install.
Sep 24, 2010 | Intel Computers & Internet
Can I install a hard drive with out caddy or run the machine from an external drivve?
Yes, you can.
Connect your hard drive and installed the operating system and drivers,
That's it,Connect the hard driver whenever you want to boot from that Hard Drive.and change the BIOS to boot from that hard drive in Hard drive boot priority.
Why not you considered booting from a USB Pen Drive.It's most flexible than booting from an external Hard Drive.
Here are fews link on how to make a USB bootable Windows.
1.http://articles.techrepublic.com.com/5100-10878_11-6160062.html
2.http://www.downloadsquad.com/2009/08/27/make-a-bootable-usb-installer-for-windows-xp-vista-7-with-wint/
Dec 27, 2009 | Panasonic Toughbook CF-51 Notebook
How to reformat my nc6000 using my os cd?
The NC6000 sometimes has trouble booting to anything other than the primary hard drive once a valid OS has been installed. If you need to reinstall by booting it USB or to a CD/DVD; this works for me as a last resort. (Especially USB which it officially isn't supposed to be able to do.)
Insert the bootable media. Shut the laptop down. Remove the hard drive - but leave it disconnected in the bay. Start the machine, let it detect the bootable device, then hot-plug the hard drive. There is some timing involved, but it works.
I loaded several NC6000 machines running Windows 2000 to Linux and XP this way.
Sep 27, 2009 | HP Compaq nc6000 Notebook
I need to install xp, but I don't have Floppy or DVD. My HDD is virgen. I think may be with USB stick, or usb enclosure, or via crossover cable, or lpt1 cable. I DON'T KNOW!!! Can you help me??? My machine...
Your XP CD should be bootable to begin with.
If the problem is that it is not bootable or that you have a SATA drive and require the SATA drivers for install - you should download a copy of nlite from http://www.nliteos.com/.
Using this point it at your windows xp install files - you can create a bootable CD image to burn or you can slipstream in your SATA drivers so that the install can be done via disc.
Aug 03, 2009 | Toshiba Tecra 750DVD Notebook
Problem installing Windows XP Prof. DG31PR (BSOD)
I had the same problem. After some experimentation, I traced it the Core 2 Duo processor that I was using. I fixed the problem by switching the CPU to single processor mode in the BIOS setting. Windows installed fine. After all the drivers and the windows updates were installed, I switched the single processor mode off.
Things are working happily ever after :-)
-K Vejju
Aug 07, 2008 | Intel DG31PR Motherboard
Intel 845GE Motherboard Logo
237 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
