Question about Cell Phones
Bh 101 bluetooth headset lost manual and forgot pairing code
Nokia bh 101 bluetooth headset was paired with old phone,got new n95 but dont remember code to pair headset to new phone
  • johnnymac77 Apr 16, 2009
    all advice correct many thanks,code was the problem for me but sorted now
  • Anonymous Mar 25, 2014
    How to pair a Roman R6250 headset to an iPhone 5s
  • 4 Answers
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Posted on Apr 14, 2009
Window 8 is not supporting ?
Posted on Jan 26, 2013
SOURCE:
Is symphony FT 40 support nokia BH 503
Please activate the bluetooth on your phone and see if it is pairing . use the pairing code to confirm.
Please check for details from manual:
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-503_apac_ug_en.pdf
Oct 24, 2011 | Nokia BH-503 Bluetooth Headset
I have Nokia 5130c, it can not identify to pair with my Bluetooth BH-101
Try to remove all the paired deviceson your phone, then make sure bluetooth is switched on i.e on your phone, then switch of the bluetooth headset and try switching it back on when its on it should show a flashing blue light on the side o on the top, when its sflashing search for new devices on you fone, if its recongised and asks you for a key type four zeros (0000), this should work
Regards
Egroeg
Mar 24, 2011 | Nokia BH-101 BLUETOOTH HEADSET
Nokia BH-101 Not Pairing with Playstation 3
Consult user manual for how to put device into pair mode, then search under bluetooth settings on ps3 if prompted enter pin code 0000. If this does not work consult usuer manual for how to do a reset on the device, it should then automatically go into pair mode. From there search and pair.
Rylan
Dec 17, 2010 | Nokia BH-101 BLUETOOTH HEADSET
Trying to pair nokia x6 with nokia BH-214 bluetooth headset i need the code to pair them
You have to hold the button down on the headset controller for approximately 6 seconds until the little LED on it flashes blue very quickly. The X6 will see it and match a pair automatically. If you just switch the headset on and the light flashes green the x6 will ask you for a passcode ... it doesn't matter what you put in (it seems) even '0000' ....it won't match the pair. HTH
Reply
Sep 15, 2010 | Nokia BH-214 Bluetooth Stereo Headset
I have a nokia bh 101.and i forgot the pass code.what should i do
The passcode for pairing is 0000 (four zeroes)
For more details, kindly download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Sep 09, 2010 | Nokia BH-101 BLUETOOTH HEADSET
Need a passcode to pair nokia BH-101 blutooth to phone lost passcode
If you haven't actually manually changed it, the password is always the last four digits of your phone number (ex. 1-555-868-2212 your password is 2212). If you manually changed it, you need to call Verizon and have that worked out.
-CompDoctor
Mar 02, 2010 | Nokia BH-101 BLUETOOTH HEADSET
Can't pair up Nokia N95 with Bluetooth BH-102
Your code is most likely 0000, with a small chance that its 1234.
Jun 30, 2009 | Nokia N95 Cellular Phone
How to connect LG cookie with Nokia Bluetooth BH 101
Put your Nokia Bluetooth BH 101 into pairing mode - this is normally done by pressing and holding the power key for several seconds. An alternate bleep will sound with a flash light to indicate that you are in pairing mode.
Now using your Cookie, press Menu > Settings > Bluetooth > Search
Your Cookie will find the Nokia BH101 bluetooth headset and then it will ask for a pass code. This is usually four zeros (0000).
You should now be connected!
Apr 10, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
How to make nokia 3230 with Nokia bluetooth BH 101
you have to pair both the devices. in the bluetooth option menu switch on your phone blue tooth and move the direction pad to right side ,you will see option as pair with devices. press that. then it will ask for security code,give as 12345 and you are paired
Oct 01, 2008 | Nokia 3230 Cellular Phone
Cell Phones Logo
3,287 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
