Question about Acer Aspire 5500 5570-2609 Laptop
Hi I have the same problem with my aspire 5570z, I have tried pressing F5...and still the LCD projector will not pick it up. It was working fine last week...and now is not :( Any suggestions?
  • 143 Answers
Try pressing the function key and f5 at the same time.
Failing that, right click on the background of your desktop while you have the computer plugged in, and select display properties. Go over to monitors and make sure you have the desired settings, such as mirror display.
Hope this helps,
Nathan.
Posted on Apr 14, 2009
Hi, I have a problem with Aspire 5570z The problem with 5570z is this: my Screen is blank with power and sound is on.
Unless the backlight has gone bad, try Fn+F5 and Fn+F6 keys to see if your display returns. Fn+F5 toggles to an external screen; Fn+F6 toggles the backlight on and off.
Aug 23, 2014 | Computers & Internet
When i try to run power point from toshiba satellite pro (to sony projector) I get frequency out of range. IT geek man has had it working in ffice by switching projector on first then lap top, but I cant...
are you using vga out on notebook ?
are you using vga in on projector ?
Turn on projector
hold down function key on notebook when turned on - FN button and press F5 - cycle through each mode by releasing f5 and pressing F5 again till you get CRT or CRT + LCD (while keeping FN pressed )
on data projector input source should be computer or vga
Jul 07, 2017 | Toshiba Satellite Pro L300 Notebook
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Feb 10, 2011 | Acer Aspire One AOA150-1784 Netbook
I need to show Powerpoint slides from my Acer Aspire One netbook. When I connect to the projector it does not work. Why?
Have you pressed Fn+F5? It commands using external monitor/ projector. Try this:
1. Connect to projector with projector in ON position
2. Restart your PC
If it won't work:
1. Restart your PC, press F8 frequently, choose "enable vga mode"
May 01, 2010 | Acer Aspire One PC Notebook
Acer aspire 5570z white screen
its either going to be a problem with the lcd, inverter or output from the motherboard probably.
Best thing to do is to try a different lcd with a different lcd cable, then if that doesn't work, then try to get a different inverter, if that doesn't work then you'll know for sure its the output coming from the motherboard.
Alot of times the LCD's go bad but the lcd cables go bad cause they are flimsy and the wires break inside.
Look on Ebay cause you can easily get these parts cheaper then most places.
Aug 09, 2009 | Acer Aspire 5535-5050 Notebook
No LCD connectivity
Hello, I am using a Viewsonic lcd projector with my new Acer Aspire One. I did not have connectivity off the bat. Here's what I did: 1. Downloaded driver (unsigned, not the signed version worked - ie not os-specific) for the lcd projector to the Acer. Restart Acer. 2. With lcd projector connected to Acer, toggle function key & F5. But then, continue holding down the function key. A screen pops up with icons for laptop, laptop/monitor, dual monitor, and lcd projector. You continue to hold down the function key and then press the F5 key to move to the desired device. I had to repeat the same process to restore my Acer screen to the original proportion when not using lcd projector. I'm not sure if both steps 1 and 2 are necessary, but I did it simultaneously, so I'm not sure of the origin of success.
May 22, 2009 | Acer Aspire One PC Notebook
I'm using acer aspire one. My SD port is not working. It can not recognize the memory card. Also when I connected my laptop with LCD multimedia projector, it did not work too. Oh my God, anybody there who...
ok ... try this, switch on your aspire laptop, then u switch on your LCD multimedia projector... then u press the F5 key on your keypad(on your aspire) , HP, and many other manufacturers uses that key for the LCD,CRT,projector extension slot while other laptop manufacturers like Gateway e.t.c uses the F4 key for the extension... after you have done that... your aspire screen goes dim then it should show on your LCD...but if not then switch off your laptop with your LCD multimedia projector ON then swicth on your laptop it will automatically work with it ok.....
this applies to other laptops and projectors or LCD s ...
Mar 27, 2009 | Acer Aspire One PC Notebook
Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Jan 10, 2009 | Office Equipment & Supplies
Acer Aspire 3680 + View Sonic Projector
does it work with external monitor ?
the key should be Fn+F5 or Fn+F6
I believe you need to hold fn and press f5 to choose the target (lcd, monitor, lcd and monitor).
Feb 26, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
