Question about Zebra P330i Thermal Card Printer
Error message Number 5 - Print Manager Print Error - The system cannot find the specified file
System error found
Hope this will help someone else:
InWindows' Device Manager (devmgmt.msc), the SXUPTP driver was showing as disabled.Windows gave a warning that the device was known to have stability issues. Ifound out that SXUPTP is a driver from a company called Silex. Silex makesnetwork USB hubs, so I assume that the Belkin hub is a rebranded Silex hub.
In order to update the Silex driver follow these steps:
1. Close the Belkin network hub's tray application.
2. Download the latest version of SX Virtual Link(sx-virtual_link_win_3120.zip).
3. Extract all of the files.
4. In Windows Explorer, navigate to sx-virtual_link_win_3120\s-33a3120\Files\Bin\Sxcsapi\WinVistaX64if you are running a 64 bit OS, orsx-virtual_link_win_3120\s-33a3120\Files\Bin\Sxcsapi\WinVista if you arerunning a 32 bit OS.
5. Right-click on "Sxuptp.inf" and select "Install" fromthe menu.
The driver will be installed and the warning icon in the device manager shoulddisappear. You may need to reboot for the changes to take effect.
Nov 03, 2013 | Belkin Computers & Internet
!!! WARNING: The switch is not usable !!! 3560-24PS
There is a possibility of IOSĀ® corruption, so better check on that before using warranty, RMA or dumpster/recycling
Error Message SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = [chars] / code = [dec] ([chars]) / bytes transferred = [dec].
Explanation This message means that the VLAN manager received an unexpected error return from an IOS file system (IFS) call while reading the VLAN database. The first [chars] is the IFS operation that failed. The first [dec] is the error code, the second [chars] is the textual interpretation of the error code, and the second [dec] is the number of bytes transferred.
Recommended Action Copy the error message exactly as it appears on the console or in the system log, call your Cisco technical support representative, and provide the representative with the gathered information.
Mar 21, 2013 | Cisco Catalyst 3560-24PS Switch
Lexmark printer error
go into the device manager and do an uninstall. this is supposed to remove most of the files associated with the application (it always leaves junk behind).
Aug 12, 2017 | Office Equipment & Supplies
I cant open yahoo messenger..so i uninstall it and then tried to download it again, but why i cant still open it..there is a error message....its says "Windows cannot access the specified device,path,...
1. Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Jan 21, 2011 | Yahoo Messenger
'Print error #5'
MYOB requires that you have a default printer selected on your computer system. If no printer driver is installed, when opening a company file, a printer error #5 is displayed.
Highlight your Printer and go to File on then Menu bar/Set as default.and Turn off user account control if you're using vista. It's in your security center in the control panel. Turning this off should fix the printer error 5 issue .
Mar 03, 2010 | Myob Accounting Plus (BPJUBC00) for PC,...
When installing I receive an error message "Unable to open serial number file". After the install, if I try to open the application I receive the error "Unable to find serial number. Please make sure the...
To all that run into this problem like I have, here is the solution:
To install Suretrak 3.0 if you get “unable to find serial#” error:
  1. Temporarily Stop the Pervasive Sql Server Workgroup engine
  2. Install Suretrak
  3. After installation, copy wbtrcall.dll and wbtrv32.dll from the c:\pvsw\bin folder and paste to c:\windows\system and c:\windows\system32
Restart computer; all should be working now
Adrian (byrdadrian@yahoo.com)
Jul 24, 2009 | Primavera SureTrak Project Manager 3.0 for...
'unable to save file. the system cannot find the path specified'
Please check the location where the file saved by your Scanner and note down its size.
Also as you mentioned in your next reply, you need to go for check Device manager. Reinstall the drivers.
Let me know if you need further assistance. Don't forget to vote me.
Regards
Ellin
Sep 25, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Purchased more memory from 256 to 512 the tech that installed the memory installed the 512mb DDR 2100 and left one of the 128 chips installed to give a total of 640mb ram receive error message "out...
Run Registry Editor (Regedt32.exe).
2. From the HKEY_LOCAL_MACHINE subtree, go to the following key: \System\CurrentControlSet\Control\Session Manager\SubSystems
3. Select the Windows value.
4. From the Edit menu, choose String.
5. Increase the SharedSection parameter.
For Windows NT:
SharedSection specifies the system and desktop heaps using the following format:
SharedSection=xxxx,yyyy
Add ",256" or ",512" after the yyyy number.
For Windows 2000, Windows XP, and Windows Server 2003:
SharedSection uses the following format to specify the system and desktop heaps:
SharedSection=xxxx,yyyy,zzz
Increase the zzz number to "256" or "512."
Best Of Luck!!
Jul 21, 2008 | Gateway Computers & Internet
Error message and won't print
change the USB cable
tray to re install the usb port from device manager
Jun 29, 2008 | Brother HL 1240 Printer
MPMan MP-F40 Manager Bug
I'm guessing the full error is "System Error &H8007007E (-214024770). The specified module could not be found." Its missing some file. I suggest you try installing it again http://www.mpmaneurope.com/download.aspx?file_id=192 it wasn't update in a while, but you can try. could be that its not compatible with sp1, or at least part of it. can you live without it? ;]
Jan 04, 2006 | MPMan MP-F40 MP3 Player
Zebra P330i Thermal Card Printer Logo
361 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
