Question about Dell Dimension 4600 PC Desktop
Noise coming from computer no speakers attached
  • 143 Answers
sometimes computers will have very basic speakers inside them.
Try going to your volume control, and selecting mute.
Hope this helped, If you need anything else, just comment in this thread and i can go into more detail.
Nathan.
Posted on Apr 14, 2009
There is always a buzzing sound come from my spekaers when i pluged in computer
Try to attach your speakers to another device, DVD player, Amp., Receiver, etc. and if the buzz is not there; then you know the problem is with the computer. Check the inputs and be certain they are clean and make perfect contact with the plug ends. If contact is positive; and the sound still has a buzz; you are experiencing line noise that requires a software fix. Down load Divx or some other application and see if that works without distortion? Match up the color of the plugs to the color of the input on the sound section of your computer. If they are incoorect, you can experience a problem there as well.
Dec 18, 2013 | Audio Players & Recorders
Level 9 Sound Designs MH-500 Computer Speakers buzzing
I think after reading your question that your speakers cable may be short or join another line. As a result, it become earthing & create noise. So you can test it by a Multimeter. The multimeter indicator point place on X10 or X100. Then you can understand where the problem in your speakers line. thanks
Nov 04, 2012 | Level 9 Sound Designs MH-500 Computer...
The big speaker are very noise
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good and is dust free
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Apr 10, 2011 | Asound 480W Computer Speaker and Subwoofer...
Hi, A few days ago I asked you about my speakers, I had whistling noise coming out of the woofer. Here is your answer: sounds like a loose connection to one of the wires in the speaker. or...
Open up your computer the speakers plug/outlet is usually at the back of the computer
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Mar 20, 2011 | Logitech Z323 2 Speakers
Connected this dual speaker to my cmpact desktop comp and it does not want to work
First step is to assure that the speakers are working. If you have no other computer or sound system to test the speakers, then attach a AA, AAA or C battery to the speakers plug. It makes no difference in the polarity. If it makes a horrible white noise, the speakers are in good working order, if it makes no noise, the speakers are at fault. Should the speakers be ok, then in all probability you have a configuration problem. Go to control panel, select Sound and Audio devices, and check that the proper configuration options have been selected, and that the speaker volume sliders are at least at the 50% mark. If this doesnt solve your problem, then a computer motherboard component might have failed. Keep me posted
Mar 12, 2010 | HP JBL Platinum Computer Speakers
One speaker has noise in it all the other are fine rh front speaker if i swap over speakers the problem still persists
What Kind of a noise is it, and is it characteristic of a single speaker [so is it this one speaker making the noise regardless of where you put it] or a single speaker jack [or is it a single port on your central unit that is causing the noise]? If you're experiencing a hum or sqeaky sound on any speaker that you attach to your central Unit, then the actual port that you're connecting the speakers to is mulfunctional. Otherwise make sure, you dont have any speaker cables running past any high voltage applicances, or even any equipment near such appliances. Another alternative would be to make sure that you speakers aren't torn inside
Jun 19, 2009 | Logitech Z-5500 Computer Speakers
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
Loud whining noise
yes,,this is due to electromagnetic interference...
try to keep the accessory speaker as far as possible fro the powerspeaker..this would serve better
Jul 04, 2008 | Bose MediaMate Computer Speakers
Static noise
Check for the Third earth wire of your computer else check for the motherboard taking earth for the cabinet.
Good luck
Oct 09, 2007 | Dell WL6000 Computer Speakers
Humming noise but no sound
It not a short but it is 60Hz hum coming from the a loose connection to ground (not properly grounded) check your power strip for proper ground, 60HZ hum is the culpurit here.
Sep 21, 2007 | Altec Lansing AVS 500 Computer Speakers
Dell Dimension 4600 PC Desktop Logo
Alun Cox
