Question about Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Craftsman shop vac no power when turn on
I have a craftsman shop vac model #113177440 won't turn on when plugged in tried different outlets was wondering if switch was bad or what the problems is
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Posted on Jun 09, 2009
Throws the breaker
Shorted armature or just too many loads on that circuit. Try plugging in a different outlet, in another room.
Feb 21, 2014 | Shop Vac 501-09-27 Original Wet/Dry Vacuum
Wet vac wont turn on
That Model of Shop vac often has on/off switch failure.
Dec 02, 2013 | Craftsman 20 gal, 6.5 Peak HP Wet/Dry Vac
Who made craftsman wet/dry shop vacs in the late 70's?
here is a link that may be helpful
http://vintagemachinery.org/craftsman/manufacturers.aspx
it details the manufactuars that craftsman used based on then model and OEM number
Feb 08, 2013 | Vacuums
Trying to vacum and it starts to blow
There are two outlets on a shop vac one to blow and the other to vacum.
Dec 13, 2012 | Craftsman 12 gal 5.0 peak hp Wet/Dry Vac -...
My Shop-Vac 5870400 was working just fine, and then one day while i vac the floor its just stop working, tried to turn on/off a few times, swicth to different outlet. i did even tried to open it, but found...
Same thing just happened to mine. My solution is to get another one but a different brand. I think it should have lasted longer than four years of fairly light usage. From what I read, if it does as we both described, the motor is shot and not worth replacing.
Feb 18, 2011 | Shop Vac 587-04-00 Canister Wet/Dry Vacuum
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Help!!! It won't start.
When you say you checked your extension cord, what do you mean by that? Were you able to ohm out the wires to determine that you didn't have an inline break anywhere? Just because you changed outlets to a known good outlet, doesn't rule out a problem with the cord, switch or motor itself. If you have access to an ohm meter, volt meter, continuity checker or even an inductive power sensor ( electritians use these all the time to find live power feeds) then you may be able to determine where the problem lies.. I did a cursory search for a wiring diagram for that particular model but was unable to locate one. Not having that information means I am only speculating what your problem could be. Is there a reset button or popout circuit breaker on that model that may have tripped? If so, reset it and try it again. If not then you may need to do some troubleshooting of the hardware itself. Not sure I've helped you at all but I tried.. Hope you can trace out the problem... Good luck..
Sep 03, 2008 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Shop vac
the neoprene sleeve used as the filter may have come off the cage. there's a plastic ring that fits over the filter and cage and holds it in place. as far other suggestions, use an old cotton sleeve from a pajama top. tie it off one end, slip it over the cage and fasten with a large wide rubber band.
Sep 03, 2007 | Craftsman 17765 Canister Wet/Dry Vacuum
Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum Logo
3,399 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Jim Parker
Jim Parker
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
