Question about Epson TM-T88III (C420863)
I have to restart my printer before printing receipts
When I am printing receipts, I always have to turn the printer off and on. Otherwise, the job will not print.
    Problem Solver:
  • 4 Answers
Look to see if your cutter blade got left un-retracted. Sometimes turning it on and off causes it to return to proper position, and next receipt prints.
Posted on Sep 08, 2009
I have to turn the printer off then on to print the next order any solution?
Many the printers will need more information to perform a printing task. Depending on the task("firmware updates") will provide necessary information to do this. Many times this goes neglected. If you do not get periodic updates for your printer, It is a good idea to browse the manufacturer of the printer. What to do at this point is to print out a self-test page to get current Driver software information. Then go to printer's support website and see if there is an current or "newer" update. Once this is in place it should be tested for it's functionality. If this solves the problem, try this insted of considering the worse. If this does not inspect the operating system of the printer that is sending information to the printer. I have come to understand many drivers for the software that some retailers use usually end up out of business or changed their name. All of these thigs should Always be performed prior to condemning a Hardware issue incorporated in a printer. Hope this helps, Best,Stephen
Nov 06, 2014 | Epson Tm-u220pa Tmu220 Receipt Printer...
I cancelled a document while it was printing and it is still in my queue days later as deleting and it wont let me print anything else or restart that print job.
The best way to delete the print job is to turn the printer off, then disconnect the cable from the printer to the computer. Turn the printer on with the cables off, and go to your computer and delete the document, Then once it's deleted, turn the printer off again, and then hook the cable back up. Then turn the printer back on. That should do it.
Good Luck
Mark
Sep 13, 2014 | HP deskjet 3940 color inkjet printer -...
Hp 4250(on a network) is hung up on processing job. I restarted the print spool and physically restarted the printer put the problem still exists.what should i do
you may need to turn off your print services on your pc. pull up the printer que on the pc. delete the jobs in the que. right click my computer. go to mange. go to services and applications .go 2 services. double left click. look for print spooler. right click. choose stop. then go to printer and reset job. turn off printer. turn on printer. restart your print spooler. close all windows and try to print
Jan 07, 2011 | HP LaserJet 4250n Printer
All connections work and icon shows that print is ready but no print
Under your printers and faxes. make sure that the print jobs arent paused. If there is print jobs waiting, try to unpause them if paused. Otherwise remove all the pending print jobs, restart your PC and make sure all the print jobs are cleared. Then give it another go.
Dec 09, 2010 | HP Officejet 5610 All-In-One InkJet...
Cancelled a job and it stays in queue
Cancel all the documents in the print queue, (just do it whether they are actually deleted or not), press "cancel" on button the printer and restart your system and also the printer. If possible, please leave the printer switched off for few minutes and don't forget to use the "Power" button to turn if off or on. This will help your printer to restart new print job, all the jobs on the print queue will be deleted/cleared. Good luck, Thanks for using FixYa.
Jun 08, 2010 | HP DeskJet 5550 InkJet Printer
Unable to delete/cancel print job while it runs-lbp 2900
Hi.
To temporarily delete the print jobs in the cue do the following:
Disconnect printer USB.
Restart printer.
Restart computer.
Access printer cue with printer not connected (get there from control panel)
Clear printer cue.
Connect the printer back.
If the printer cue gets stuck too often, and always with different documents, try reinstalling the printer software.
Regards.
Ginko.
May 26, 2010 | Canon LASER SHOT LBP-2900 Printer
I just changed my ink cartridges. The test page will print, but the computer page I'm trying to print...won't. In the bottem righthand corner the printer icon keeps blinking along with a left facing...
hi,
First of all would like to help you so that you can cancel your print job.
On the bottom righthand corner where the prinetr icon blinks simply right-click it and select "cancel," after which the print job status commences to display "deleting..."
So you shoud not be worried about loosing your receipt as you can print it again.
Also
  1. I would like you to unplug the USB wire connected from your computer, turning the device off and then connecting everything from scratch. You can also restart the computer.
  2. Then once the computer is on please click on START and go to RUN and type in services.msc and then on the right side of the page find print spool and right click, then choose restart.
And then try for fresh prints.
Please let me know if the above information helps.
Feb 09, 2010 | Office Equipment & Supplies
Out of paper clears print que
we need to restart the print spoolers to fix this,
click on start> Run> Type in services.msc. A window will appear with the list of services, there u will find Printer Spooler> Do a Right click on that and Restart it. Do the same thing 2-3 times and then give the command to print multiple documents, to check if the problem is fixed or not. Please let me know the same.
Aug 05, 2009 | HP Photosmart C7280 Laser Printer
HP 7680 is "mirror" printing. Latest driver has been downloaded again. Mirror printing feature is "off,"but it's still mirror printing. Anyone have a solution??
Open Printer jobs and delete any print jobs pending. Restart Computer.
Otherwise, uninstall all printer software, disconnect printer, restart pc. resinstall software
Apr 09, 2009 | HP Officejet Pro L7680 All-In-One Printer
Epson TM-T88III (C420863) Logo
162 people viewed this question
Top Epson Televison & Video Experts
janman
Terry Dovre
Terry Dovre
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
