Question about Sanyo DS35510 35" TV
DS 27425 sanyo
Hi,I have a sanyo tv that woun't turn on,no picture or sound.It is a year and a half old.Thank You
  • mprather1 Jan 10, 2008
    I have similar problem, but model is ds35520 Sanyo. Was watching and just went blank, no sound, or picture, totally dead. Could smell burnt componets after. Had been strong lightening storms previous day or two, but nothing the day actually quit. Have worked on electronic circuits for years but not much in the way of televisions. Would like some likely causes, and where to get service manual.
    Thanks,
    Mark P.
    Scholar:
  • 135 Answers
Hi there!
Your problem may be the same as "Mark P". Components may have been partially damaged during Lightning and failed after a while only or if caps get damaged they will overheat the circuit and cause other sensitive components to fail. I would start with primary and secondary supply and work your way through to all sections. If not familiar with TVs, refer to repair technician. Good Luck, JUS004
Posted on Mar 05, 2008
SOURCE:
Sub picture of my sanyo lcd-32k30 in pip/pop are not clear
my sanyo lcd 32k30 have a problem when i turn on half on the screen the picture is ok and the half is black after a few seconds the picture is full what is the problem? can you help me of this trouble of my sanyo lcd 32k30 thank you
Jul 19, 2011 | Sanyo DP19649 LCD TV
My name is shakena brown, i have a sanyo 32in flatscreen TV that I brought from Wal-Mart. The TV is not an year old yet and it will not show anything. When I plugin the cord in and turn the TV on the...
Your set is still under a manufacturer warranty. Take your set back to Wal-Mart and they will send it out to be repaired, or give you a new one.
May 19, 2011 | Sanyo Televison & Video
I GET SOUND BUT NO PICTURE, MY TV IS ONLY A YEAR AND A HALF OLD
You have to check your connections. Switch off your TV. Remove all the connection sand clean them with a cloth Wait for sometime. Reconnect them. Also check your cable connections. If you are using dish check at both ends. If you are using cable the check connector at TV. Switch on your TV
May 14, 2011 | Sanyo Televison & Video
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
No picture, no sound.
contact sanyo, sounds like your display panel has gone bad
Sep 08, 2009 | Sanyo DS31590 31" TV
Sound but no picture
hi..
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem..
thank u
rate me
Jul 13, 2009 | Sanyo Televison & Video
Sanyo ds-25350 TV won't turn on, just clicks twice
Sanyo ds-25350 ? Not recognising that model number.
Sep 16, 2017 | Televison & Video
Sanyo clt1554 has sound no picture.
I have a Sanyo CLT1554 (2 1/2 years old). Has perfect sound but no picture. The picture will come after several times turning it off/on and pressing the Reset button. It is very anoing to do this evey time. PLEASE HELP
Dec 15, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Sanyo HD Tv
Sanyo makes excellent TV`s. You may have weak electeolytic capacitors in the power suppy causing the delay in starting up. It might be worth it to have a shop look it for you
Nov 05, 2007 | Mitsubishi VS-5043/44 50" Rear Projection...
Sanyo DS35510 35" TV Logo
87 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
