Question about Fuji FinePix J10 Digital Camera
It says ZOOM ERROR when i turn on the camera
The camera is totally fine and i didnt drop it or anything. all of a sudden everytime i turn it on it says "Zoom Error" and shuts off. yet the lens is totally in tact...im so confused. somebody help !
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
Zoom lever stopped working on Panasonic lumix DMC-FZ8
Does it say anything about the lever under zoom levers in your owner's manual?
Nov 07, 2012 | Panasonic Lumix DMC-FZ8 Digital Camera
Zoom error, Fujifilm J150w
I just pulled apart the camera, everything inside was intact. No cogs broken. couldnt find anything to fix (not a camera expert by the way).
In desperation even put some WD40 on the lens barrel - still no luck.
Camera turns on - barrel is stuck out. Wont zoom, wont go back in and wont take a photo.
Daughter's camera and she says she didnt drop it but just saw it on her desk with the lens out...
Would be good if someone could shed some light on the problem.
Jul 05, 2009 | Fujitsu Cameras
:( please help - lens problem
time for a replacement camera...as the repair wouldn't be to expensive to consider.  Use your wrist strap
Apr 01, 2009 | Casio Exilim EX-Z30 Digital Camera
Zoom error
Some time later it suddenly worked again.
Jan 04, 2009 | Fuji FinePix F30 Digital Camera
Zoom error
It appears that the moving parts of the objective(those that go in and out when you zoom) could be damaged.This occures when the camera is dropped-in this case the most you can do is cleaning the moving parts and try gently to shake them or do anything that may unblock it.
Another blame could be the weak batteries or acumulator of your camera.Try get some new batteries or charge the acumulator.
A final thing you could do is reset to default the camera settings.
If any of these won't help, I suggest you should go to a specialised service, cause the problem-more common than you think- could be serious.
Good luck Smitty
TigerFly
Sep 04, 2008 | Fuji FinePix V10 Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Zoom problem
Ive seen this three times and everytime its been something differant. Fist was the rocker switch was jammed. easy fix as dirt was in there. Second was a small serface maounted capacitor in the zoom interface circuit. An third never found the problem as we thought it was a limit switch in the lens itself but the customer never paid for a new lens assy so we didnt order it. Good luck
Jun 21, 2006 | Canon XM1 Mini DV Digital Camcorder
Fuji FinePix J10 Digital Camera Logo
56 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
