Unfocus colors sceen
My RCA 52in. hdtv is showing unfocus colors
  • 147 Answers
Very likely there are bad connections on the flyback transformer and a fuse has opened up. The convergence circuit is not working. this is not easily done yourself unless you have some experience.
Posted on Apr 14, 2009
My 56 inch rca tv has 3 difrent colors on it turns on ok but show s it like their is 3 of everything on the tv
This is a common problem and is known as a convergenc failure. You can get parts and instructions from sites such as www.TVRepairKits.com
Aug 18, 2011 | RCA HD56W66 56" HDTV
I have a RCA 52in TV & the picture is arched. Model # is D52W15.
Problem description indicates a convergence alignment issue. Convergence circuirty needs to me replaced.
Jan 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52in HDTV when you cut it on the picture shows good but no sound
try retune or unplug it leave for 30 seconds and try again it worked for me friend
Dec 11, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Colors separated and has a bow in top and bottom of sceen
Is the autoconvergence option still listed under the setup menu or has it disappeared/ Let me know and I will assist you.
Aug 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA 52in. has a blue screen... Will not show a picture?
  1. Check menu to make sure a signal is present. try video 1 with a external video source such as a VCR. If this produces a picture check for tuner signal by hooking the VCR to the antenna and tuning to channel 3 or 4. If their is no picture check antenna connector on back of set for looseness. If loose resolder antenna connector in tuner. If all these test fail the tuner may be defective and will require replacement.
Oct 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W23 52in HDTV red and green ghost and bowing lines
Ur convergence it dead,need convergence kit,use what in that kit,U know to solder? Tries websites Tv Repair World.com,Ebay.com
Oct 06, 2009 | RCA D52W23 52" HDTV CRT TV
Rca 52in rear projection hdtv red, blue, and green lines n double
tHIS is a convergence problem.. first question if you go into the customer setup menu. is the convergence option listed? If you have not got that option i suggest you read "the fl231 problem in the tips and trick section of this website. this can be a simple inexpensive repair..if you do have the convergence option then it can be one of three diffrent boards convergence power, convergence amp or small signal board. and will need further trouble shooting
Apr 04, 2009 | RCA Televison & Video
Colors disorted
Hi
this cause by a defective convergence IC, this ic nedds to replace
Mar 06, 2009 | RCA P52926 52" Rear Projection Television
RCA D52W20 52in Rear Projection TV/ Picture
Sounds like someone has put a magnet near it or picture projection from rear may have moved is the picture fine other than tinting?
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
