Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
F2 CODE OVEN OVERHEATS NO CONTROL
SCE30600 F2CODE, OVEN OVERHEATS CAN'T CONTROL
    Problem Solver:
  • 7 Answers
Try a new sensor 1st, then you may have to replace the ERC. Sensor usually solves.
Posted on Jun 05, 2009
I get an F2 error code and the broiler element will not shut off, even when oven is turned off! Had to flip circuit breaker to shut it down. What part do I need?
Follow the wires from the sensor to the control board and check the ohms there. It should be around 1050-1100 ohms, if the oven is at room temperature. If it is close to the correct ohms replace the control board. Probably a stuck relay on it.Here is the board to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 22, 2013 | Jenn-Air SCE30600 Slide-In Electric...
EO F2 The oven will not start or stop. I can not get the oven to work but it will beep with this EO F2 message sometimes.
Hello Sonya,
The E0-F2 error code means that the oven temperature was higher than it's supposed to be. Usually the oven overheats because of a defective oven temperature sensor and the sensor should be checked. 11_3_2011_2_07_54_pm.jpgthis is what the sensor looks like...it is located within the oven chamber(usually in the left side) to check it,it needs to unplugged and using a mulitmeter set to measure ohms,check the sensor to be between 1060-1100 ohms at room temp. if the sensor is way lower/higher that 1060-1100 at room temp the sensor is bad and needs to be replaced, if the sensor is within that range then the control board is the problem.
GENE
Nov 03, 2011 | Whirlpool RBS275PD Electric Single Oven
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Oven doesnt work getting f2 code
F2 Indicates the following
Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode.
Remove oven temp sensor located inside oven near back top. It's a long thin tube like part. @ screws hold it in. Pulls out easily. Check with ohmeter, should read about 1100 ohms +- 10% if not within range main relay control needs to be replaced. For diagrams and illustrations of your specific model enter your model # at www.appliancehelponline.com All parts come with installation instructions. Both of these are very easy to replace.
Apr 12, 2010 | Jenn-Air SCE30600 Slide-In Electric...
What is f7 jennair sce30600
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Aug 11, 2009 | Jenn-Air SCE30600 Slide-In Electric...
E1 f2 error
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked - If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F2
Note: Also see fan thermal switches - Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem.
· Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
Good Luck
Sep 05, 2008 | GE Profile JT912 Electric Single Oven
GE self cleaning radiant oven - model JB578GP
I went out to my circuit breakers and turned the circuit off, let the oven cool, and powered it back up after about 2 hours. Fine now.
Feb 17, 2008 | GE Profile JT912 Electric Single Oven
Oven element
bad relay on erc(electronic range control), or and open thermaostat wired in line with element you would need to pull unit and check wiring
Feb 07, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Jenn Air Range SCE30600
i would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Missing manuel Code showing - F 2 -
hi,
F2
F2
Oct 31, 2007 | GE Profile JT912 Electric Single Oven
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
156 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
