SOURCE: power light vs. protect light mode
If the power light on top of the amp is on, the internal power supply is operating.
It is possible that the amp could damage the speaker if it has blown output transistors. Before you connect a speaker to it, you should measure the DC voltage across each pair of speaker terminals. If the DC voltage is more than a fraction of a volt, the amp needs to be repaired.
The amp requires an external fuse. Download the owner's manual from the rockford site.The correct fuse for the amp will be specified in the manual.
SOURCE: My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
SOURCE: t1500-1bd burnt mosfet
Fosgate's get very hot.My first amp was a fosgate and I freaked out because it got really really hot. And smelled bad. So I moved it so where it could get more air That should help you out a lot and the smell went away on its own. As for your battery dying. Basically your stressing out your battery and your alternator is having a hard time keeping the battery changed. I'm sure you see your light dim when a low bass note hits. Invest in a cap. This will help save your battery your alternator and should even sound better.
SOURCE: I'm looking for a wiring manual for a punch 150 amp
Follow this link to the downloads page for Rockford Fosgate, you can choose the correct manual there.
LINK
SOURCE: i hooked up a punch
check to see if your ground is bad and all of your wires to the amp are wired correctly, in the worst case, you may just have a bad amp
Who can help me with this product p6001bd Rockford Fosgate punch that I burn resistance and is not seen the code it can be to buy and assemble thanks
