Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
LE trouble code
Machine shuts down, flashes LE on display
  • 641 Answers
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Many times owners experiencing the LE error code are using regular detergent. It is recommended to use a high efficiency or low sudsing detergent. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire, dislodged ball sensor, or if the shipping bolts are removed prior to situating the washer. Good luck!
Posted on Sep 13, 2007
  • Dov Dror Sep 13, 2007
    My first solution was relates to the LE code for the washing machine.
    I believe that your error code is "IE".If so,its relates to water input problem.
    Check first the filters on the inlet water line (both sides).
    Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)).
    If it doesn't work, test that it get power. In case it get power and doesn't work - You should replace it. Be aware you should disconnect the power cable from machine before doing it !!!!
    Good luck
SOURCE:
AFTER 15 MINUTE FROM OPERATION I SEE ON SCREEN SEMBOLE LE AND MACHINE STOP
Please check on the error codes list for LG machines and confirm if the codes seen is LE.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6333
Since the machine shuts down after working for few minutes , it is possible that it shuts at the time of drain and the suspect can be a damaged or clogged drain pump.
So check the voltage on the drain pump at this time to confirm
Thank you for using Fixya
Sep 24, 2011 | LG Washing Machines
When i started my machine after play for washing its showing LE on display
You didn't state the make or model of your machine, but I'm guessing that it's an LG machine (It's the only one that I can think of at the moment that produces an "LE" error.
LE Means LOCK ERROR - the trouble shooting information says this means taht the lead wire assembly is not connected. What this actually means is that the little switch that is sat behind the door catch that locks the door shut once the cycle starts isn't working. Most likely because a wire has fallen off the back of the switch, or the switch has failed open circuit.
If you take the lid off the machine and tip it back so you can get a clear look at the casing of the machine from the inside, you should be able to see the switch immediately behind the door catch that you can see from the outside. If you're lucky, you will see a connector, hanging in the air where it has come off a spade connector on the switch. If you're unlucky, the switch may need replacing, if you're really unlucky, the wiring may be faulty somewhere.
Jun 29, 2011 | Washing Machines
DIGITAL DISPLAY SAYS LE
Hello, W/D here.
The LE code indicates that the dishwasher thinks that there is a leak, and the leak detector shut the machine down and displayed the LE code.
If you in fact have a leak, it should be repaired either as warranty work or by a reputable repairperson. The LE code can be reset by turning off the circuit breaker controlling the power to the dishwasher for several minutes, then resetting it.
If you have a stainless dishwasher, it is guaranteed for life (usually) against leakage. Samsung will require a service call by their tech, and if the unit is unrepairable, will depreciate the unit before offering a refund. Not great. The good news is that these are fairly robust machines, and leakage might be no more than the door seal. Check the seal and reposition it if necessary, as they not only tend to flatten out, but they also tend to pull out of their grooves holding the seal in. It seems that in making the "tall tub" types, there is less space between the racks and the seals. Larger objects, especially on the upper rack, can bump the seal and pull it out of position a bit, creating a leak. It doesn't take much.
If you bought your machine from one of the major hardwares, and you got the extended warranty, they will make three attempts to repair the unit, then replace it if unsuccessful.
Hope that this was helpful to you. --W-D--Please feel free to rate this solution. Thanks.
Feb 21, 2011 | Samsung Dishwashers
F35 error
D?FAILLANCE DU CONTACTEUR MANOM?TRIQUE
If after 30 seconds the control does not detect water
entering machine, the valves will be turned off and the
error code will be displayed. OR If the control has
turned the water valves on and after 8 minutes the flow
sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip,
the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Si apr?s 30 secondes le syst?me de commande n’a pas d?tect? l’entr?e d’eau
dans la machine, le syst?me ferme les ?lectrovannes et commande l’affichage du
code d’erreur. OU Si le syst?me a command? l’ouverture des ?lectrovannes
d’entr?e d’eau et si apr?s 8 minutes le capteur de d?bit a d?tect? le passage de
10,5 gallons d’eau, tandis qu’aucune manoeuvre du manocontacteur n’a ?t?
d?tect?e, le syst?me commande la fermeture des ?lectrovannes et l’affichage du
code d’erreur clignote.
Appuyer deux fois sur la touche PAUSE/CANCEL pour commander l’effacement de
l’affichage.
Possible Causes / Procedure
1. Unplug washer or disconnect power.
2. Check to verify that the pressure switch is
operational.
3. Replace pressure switch.
This is for an F32...there is no F35 fault code on your model according to the service manual....
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
" LE " displays
lg washing machine shows an error everytime i turn it on error such as pe
Nov 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Problem with LG washing machine Model number wm1480fhd. The machine drum reluctantly turns and in about a few minutes it displays error code LE (flashing).
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 22, 2008 | LG Washing Machines
Shows "LE" in display.
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
1,985 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
