Question about HP Computers & Internet
Cant get into my incredi mail
I was tring to add a password to my incredimail account, went through the instructions hit okay . thought every think was all right .then it said welcome to my new account. lost my original account , tried to rectify it but it keeps giving me new account .(i must have a dozen by now)can i get back my old account ,or is it lost for ever ,with all my folders and address
My p/c was reset recently and I just downloaded incredimail what do I do now? am 87 yrs of age, so please help
Remember, you can return to this page via your link in your email. (You must have an email account to be here, I suspect.)
Incredimail requires some setting up. I can supply you with a page offering instructions on setting it up to receive Gmail. However, those instructions get to be a bit technical.
I simply use Gmail (Google Mail) which I access from my browser. It only required I sign up, choose a password and user name, write those down and go back to the sign in page when I want to access it. If you wnat to use Incredimail, setup your Gmail account first. Write down password, user name and gmail address on paper. Then launch (might as well take a look at the links below first) Incredimail and follow the below:
http://support.incredimail.com/hc/en-us/articles/230695567-How-do-I-configure-my-Gmail-Email-Account-in-IncrediMail-
If those instructions are not enough, here is an extensive guide from Wikihow:
How to Access Gmail in Incredimail Desktop
And here is help on using Incredimail itself.
Help Center Using Incredimail
Sep 06, 2017 | IncrediMail Computers & Internet
Need help to correct Incredimail send/receive mail problem?
Hello friend,
I Guess this is common problem you don't need to worried about that you just have to reset all mails setting by following these steps.
When your Incredimail window is open click on the tools that's mention on top of Incredimail window, then go to your @email account and add E-mail you want to receive mails from then reconfigure email account automatically or manually you can also use user E-mail users like Gmail, Yahoo, AOL, Roadrunner, hope it'll work for your sending and receiving trouble because this information is out from Incredimail support website
Jan 18, 2017 | IncrediMail Computers & Internet
Incredimail says error authentication failed
This means that your account details have changed and are incorrect. (i.e. password or username) Incredimail suggest the following course of action.... (But, that said, yu shouldn't need to delate the account, just go into tools, accounts, and then properties - you should be able to change things there... Have you tried your ISP's webmail login, to validate the username/password.
First remove your Email Account configuration, and then Reconfigure it again:
  • Open IncrediMail, click the 'Tools' menu and select 'Accounts'. In the 'Mail Accounts' dialog, select your email account and click 'Remove'.
  • After removing the account click on 'Add' and reconfigure your email account.
Please check that your Username and Password match the one given to you by your Email Provider!
Nov 15, 2013 | Computers & Internet
I have incredimail 2 and when i add a yahoo account it says that it has an invalid username/password and won't recieve emails. I can log on to my account online though
You must pay for Yahoo Mail Plus to receive your E-mail through a client such as Incredimail. Sorry for the inconvenience.
Aug 11, 2010 | Computers & Internet
Had to re-install Wind XP. Made sure Incredimail was set to leave copy of mail on server and reinstalled all progs inc IM. It found and uploaded 8000 emails from Yahoo but then over wrote latest backup. I...
yes if you configure your account again then you can receive all emails again.
For that you have to configure new account for your email account and delete old email account but noter down all settings of email account before delete.
Then create new email account and set all settings make sure check box is enable for "leave copy of email on server".
Let me know if you need further assistance.
Thanks..
Oct 29, 2009 | Computers & Internet
I cant access my yahoo mail? ERROR CODE 1
I think you might be able to use a mail program like windows mail or incredimail (free download) and then import your yahoo stuff, Yahoo is a pop server so you should be able to open windows mail create a new account and get the server information from yahoo support, I know the one will probably be pop.yahoo.com and the smtp server should be smtp.yahoo.com not too sure but give it a shot...Steve
Jun 13, 2009 | Yahoo Mail
My Incredimail account all of a sudden won't work and it tells me that It can't connect to my e mail sever.... that is YOU> I can go through mail.fitisitcardio.com and get my mail, but Yahoo won't...
What opperating system do you have,
Windows XP or Vista? Just courious incase I need to help you further.
Bring up Incredimail and click on tools.
Click on Accounts.
Then on the right side click on remove.
Next click on Add.
This will bring up another window and click on the Automatically Configure Settings.
Then just follow the instructions.
(What I think is that some how your e-mail settings have been changed. Hopefully this will help.)
When finished it should work. If it doesn't I will assist you further. If I could talk to you it would be so simple to get it working for you. Bud
Jan 19, 2009 | Computers & Internet
Cant send my emails from incrediables email
Who's your email provider. I had the same problem when sending mail through Thunderbird using my AOL account. You have to manually change the outgoing mail server (if your provider uses an IMAP server) and change the port number. The default is 25 but in my case, it was 587. Yours may be different. You can search for more info about your provider by searching how to configure to send and receive mail with Incredimail.
Sep 28, 2008 | Computers & Internet
My incredimail
Remove your current email account from incredimail and add a new email User e.g., karebear@(who ever your ISP is)
Please give me a rating to let me know that I have resolved your problem.
Jul 10, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
