Help with insterlation of hp5650 printer - Computers & Internet
  • 137 Answers
Installing an hp 5650 printer is as simple as plugging it in and downloading the drivers from Hp.com. type in your model when asked under support tab and they will download to your desktop. I doubt that printer will work with the new Windows Vista, but it should be fine with XP, 2000, 98 or 95.
Posted on Aug 14, 2009
How do i get back onto facebook
https://gethuman.com/phone-number/Facebook
The link above above has both phone number support and email support. Good Luck.
Feb 06, 2015 | Facebook Social Network
For an HP5650 and a cartridge #56; not one cartridge right after another but I'm on a third cartridge that prints characters/images OK as the page begins than slowly fades as the paper moves through...
hello
it may be possible that the printhead needs to be replaced. it usually has to be replaced after 2- 3 years of use. there have been reporst of issues with this particular printer.
also, go to this site to follow instructions -- how to maintain this printer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013609&lc=en&cc=us&dlc=&product=71896
May 08, 2011 | HP Officejet 5610 All-In-One InkJet...
I removed The deskjet ink cartridges(56/57) in my HP5650 to replace them with new ones. However, I am unable to install the new ones as the two bottom trays to hold them will not move. Can you help Joe...
Usually when you open the cover the cartridge holder should move to the center that will allow you to install the cartridge. If this is not the case you could force it to move by:
  1. Opening the cover as if you're installing a new cartridge.
  2. Unplug the power cord
  3. Lift the cartridge holder enough height to allow you to slide it on to the center
  4. After sliding, you should be able to install the new cartridge.
  5. After the installation close the cover and power up your printer.
Feb 24, 2011 | HP DeskJet 5650 InkJet Printer
My L350 isn't opening the desk top, instead it says Windows failed to start a recent software/hardware may be the cause. To fix the problem insert your insterlation disc (I dont have one).
Restart the computer and after it does the POST (before Windows is suppose to start up), hit F8. Select last know good configuration or safe mode.
Nov 12, 2010 | Toshiba Satellite Pro L350-S1001X Notebook
HP 5600 series Lid won't close properly so can't get anything to print. when I start to try to print the power button and the ink low button both flash but its not short of ink. If I press the resume...
On the HP5650 there is a switch on the right hand side at the top. The switch is flush with the inside surface under the cover. A tab on the right hand side of the cover is supposed to depress this switch telling the printer the cover is closed. If the cover is warped (mine was) or if the tab has broken off, you can manually depress the switch with a pen-point (or just hold the cover at that point) to get the printer to activate.
May 02, 2010 | HP DeskJet 5650 InkJet Printer
Ink light keeps blinking on hp deskjet 5650. Followed HP's directions for cleaning cartridges, as the utility that came with the printer does not work on Vista, but still will not print.
Check 16V leg of power supply. I had same problem, but since the carridge and lights worked I assumed power supply was OK. Tried all kinds of things but nothing worked so I replaced the HP5650 with another one. Same problem. Changed power supply and both printers worked. When I put a DVM to the original PS I had the 32V leg but the 16V leg was dead. Who would have thought?
Apr 21, 2010 | HP DeskJet 5550 InkJet Printer
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
I NEED DRIVERS FOR MY CANON MP390
cannon have a web site to download drivers. if you have lost the insterlation disk.
Mar 25, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Insterlation of hp deskjet f2280
Hi!
Try this, folow the link bellow, select you OS, download the drivers, install them from that downloade file
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3390947&lc=en&cc=us&dlc=en&submit.y=8&submit.x=3&lang=en&cc=us
I hope i work for you
Good luck
Nic
Mar 05, 2009 | HP Office Equipment & Supplies
HP5650 Deskjet Carriage Stuck
hello dear; open the door let cartridge move to center, then UNPLUG the power, try to push the cartridge by hand left to right just investigate see where got stuck what cause this problem I believe you can make it. still have problem let me know.
Dec 29, 2008 | HP DeskJet 5650 InkJet Printer
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
