Question about HP OfficeJet 4215 All-In-One InkJet Printer
Will not print
I installed a new photo cartridge, after which I printed one picture. After that the printer won't print anything else that I send to it, it stays on the fax option.
  • 22 Answers
What is the error message on the screen ... please remove cart trun off printer and start again and insert cart again
you will see error message on the screen... if this stays on fax than you have pressed fax button
Posted on Apr 14, 2009
Why do my pictures have lines across them?
Try running one or two ink cartridge cleaning cycles to help clear the air out of the ink nozzles. New cartridges aren't always perfect to begin with. After doing the cleaning try running a test print from your printer setup or installation properties window. If this print is good try printing another picture on a plain piece of paper rather than photo paper. If it prints OK then use your photo paper. I say this so you don't waste your photo paper. If you get lines in the test print, return the cartridge and see if the place you bought it from will exchange it for another one. If they will not exchange it try to get them to make the cartridge print correctly. You may have to bring your printer to them. This is the best advice I can give you, I hope it helps.
May 27, 2015 | Canon PIXMA Office Equipment & Supplies
My printer is full of ink but when I print anything with colour it had horizontal lines going through it
This problem is pretty much the same as the question I answered a few seconds ago. I am going to give the same answer. Try running one or two ink cartridge cleaning cycles to help clear the air out of the ink nozzles. New cartridges aren't always perfect to begin with. After doing the cleaning try running a test print from your printer setup or installation properties window. If this print is good try printing another picture on a plain piece of paper rather than photo paper. If it prints OK then use your photo paper. I say this so you don't waste your photo paper. If you get lines in the test print, return the cartridge and see if the place you bought it from will exchange it for another one. If they will not exchange it try to get them to make the cartridge print correctly. You may have to bring your printer to them. This is the best advice I can give you, I hope it helps.
May 27, 2015 | Office Equipment & Supplies
Epson Stylus Photo R220 Ink Jet Printer won't print with new ink cartridges
Silly question: Did you remove the plastic tape from the bottom of the cartridges when you installed them?
Apr 30, 2012 | Epson Stylus Photo R220 InkJet Printer
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
I installed a new colour cartridge but the teardrop keeps flashing and I can't print anything.
might have to clean off cartridge contacts and those on cartridge carrier. Use isopropyl alcohol(don't touch nozzles)! and wipe clean.
print test page and/or photo. Align cartridges from maintenance menu and good success......Please rate if it helped. Thank you. Meder's tv service.
Sep 12, 2010 | HP Deskjet 6980 InkJet Photo Printer
Poor photo printing quality with new color cartridge
Shaking these cartridges does nothing except give you a little exercise. If this is a brand new HP cartridge you are having problems with I would return it to the store you purchased it from. HP brand cartridges should not give you these problems right out of the box. The print defects you are seeing are due to a dried up or clogged print head. If you like you can try hydrating the print head on a water soaked paper towel until the ink starts flowing, but there's a risk you will cross contaminate the colors.
Oct 08, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Lines on photo's that i print
Usually the refilled cartridge is not guaranteed to print very well. But still the follwowing tips may help you out.
1. Clean the print cartridge nozzles with an ear bud dipped in light water. Dont touch with hands and other materials.
2. Using your printer utility software installed in your machine, activate the clean cartridge functionality (usually HP printers will have such options)
3. Most important tip - Align your print cartridge ( Again using your printer utility software installed in your machine). It will print some sample lines and colors to a paper and you have to enter appropriate details back into the printer utility for proper calibration of your printer. Just follow the steps shown by the printer utility software. This step have to be done even if you install a new cartridge.
If none of the above step solved your problem, then its time to get a new cartridge for your printer.
I hope this is helpful to you :)
Aug 31, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer not printing in color; new cartridge, tests are fine
Check your printer settings to make sure the print in b & w box is not selected. Hope this helps.
Feb 08, 2009 | Dell Photo 964 All-In-One InkJet Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
44 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
