Question about Daewoo DSP4210GM 42 in. Plasma Television
Daewoo PD42S20W has scrambled picture
I just "inherited" a plasma from my boss. He said he thought it was junk because someone had laid it down when they delivered it. The screen comes on clearly sometimes, other times it is scrambled. The "scrambled" picture really doesn't follow any particular pattern. I know that the machine is out of warranty, but was wondering if it's something I should look into fixing.
  • Oralondo Solomon Sep 25, 2007
    A little more information about this problem. I can tell that there must be a short somewhere, because I can do the "whack" test and get the screen to clear/scramble. Though I work on electronics for a living (mostly copiers and cash registers/POS), I can't seem to find a schematic for this model since it seems to be one of their older plasma models. If anyone knows how to get one, that would be appreciated.
  • frankflintst Apr 23, 2008
    I have the same issue but i have had mine since brand new and all of a suddon it does exactly what your is doing and im looking for someonto fix this . let meknow if you hadany luck fixing yours [email protected]
SOURCE:
SOURCE: Flicker
I had the same problem with the flicker. Mine was a Flicker followed by a greenish line through the screen. It got worse then after 2 months the tv stoped working the power didnt come on at all. I Im taking it to bget fixed. The guy said it has somthing to do with a burnt out switch in the unit.
Posted on Oct 20, 2007
SOURCE: Our 42" plasma tv will not show a picture or anything else.
I have parts from my tv for sale 42" daewoo plasma
email me at [email protected]
Posted on Jun 02, 2008
  • 55 Answers
SOURCE: PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
Posted on May 09, 2009
  • 6 Answers
SOURCE: plasma 42" daewoo edtv black line down middle
Attempting the solder fix is a big undertaking, gaining access to the components is a MAJOR undertaking, and probably not worth your while.
If it is simply one line you might try the baseball Bat fix....
In reference to the "basebal Bat fix" it works on occasion by using percussive force to realign the ribbon cables.
DO NOT use a baseball bat, but use a rubber mallet and with the power off tap gently directly above and below the offending line.
Its worth doing this if yo cannot live with the line.
If you can live with it, leave well enough alone!
Posted on Aug 24, 2009
SOURCE: Daewoo Plasma dp-42sm
Just answered this on a different one. I have the Daewoo Plasma Digital Dream model dp-42sm, My dads tv expert friend looked at it and told us the ysus board was out. I got on ebay and bought the item from a store for 125 dollars used tested good with 12 dollar shipping, I put the part in myself it was very simple just take your time dont try and rush you have to take the actual bar the stand hooks onto off and the 2 boards going into the ysus board. It fixed the problem and is still in working order im using it now as the computer monitor.
Posted on Feb 13, 2010
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
After being on for a whilemy plasma tv picture scrambles. After it cools down the picture is restoredwhat could be the cause
Your plasma is over heating! This is not a good situation for the tv as the components are only rated to their highest temp of 105 degrees C. (IF there are quaility parts inside). Some plasmas are only rated to 85 degrees C. I would recommend installing an internal fan or keep a fan behind the plasma to help cool it during its' working hours!
Please rate if this helps :)
Mar 09, 2011 | Maxent MX-42HPT51 42 in. Plasma TV
32 INCH ZENITH PICTURE IN PICTURE ABOUT 15 YEARS OLD.PICTURE DISAPPEARED AND ONLY HAVE A THIN WHITE LINE RUNNING ACROSS THE SCREEN.THE SOUND STILL WORKS FINE. IS IT WORTHWHILE GETTING IT REPAIRED ??
When CRT TV's show only a white/bright line horizonatlly It is a failure of the flyback Transformer. Not all that costly to repair. Your old TV will probably still be working when all the latest plasmas and rear projections have been laid to rest. Fancy junk TV's dont get any better programs than those old reliable ones
Please rate my help++++Thanks for using FRIXYA
Aug 04, 2010 | Televison & Video
Onkyo TX-SR706 Setup Display Problem
For adjustments to receiver you can always run a component or composite cable to your plasma tv. After adjustments are made just return to HDMI input.
Feb 24, 2010 | Audio Players & Recorders
The picture is scrambled from start and never gets normal
You have numerous Surface mounted capacitors to replace in you PIP module. This is not and easy repair for the average person to attempt. The module is No Longer Available so we repair the original.
Jul 11, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Broken glass on plasma tv
The glass is part of the screen. It will probably cost more to buy the part than a new TV would cost.
Dec 08, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
Pd46c10 daewoo plasma
I have a DAEWOO PD46C10 recently it would come on display a beautiful picture play for 10 minutes and the screen would go black.After several minutes reset turn it on and the process starts again.Whats the problem and where can I get it repaired???????????
Nov 25, 2007 | Televison & Video
Daewoo DSP4210GM 42 in. Plasma Television Logo
240 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
