Question about KitchenAid KTRC22EM Top Freezer Refrigerator
We have a kitchenaid ktrc 22e and it has just started thumping intermittently. I think it sounds like the copper pipe for the ice maker on the back of the refrigerator, but haven't got it totally narrowed down. What could it possibly be?
I found out it's not the refrigerator, but a woodpecker knocking on the dish on the roof right above the refrigerator. Go figure, not a refrigerator problem... ;)
Posted on Apr 15, 2009
The ice maker quit a few months ago (water still works) but I hear dripping into the drip pan.
sounds to me that ice tray fill tube is broken in the back as it runs up from the bottom to the tray , could that be the source of the sound of running water u hear ??? ill bet its intermittent , say 30 sec every two hours ??? and it stops making sound if u turn off ice maker ??
May 04, 2016 | KitchenAid Superba KSCS23IN Side by Side...
Could some please post how to remover the ice maker from my kitchen aid model ktrc 19 m refrig thank you
Look right above the icemaker part that forms the cubes. Its usually brown in color, Just above it are 2 extensions of that brown part that has 2 screws going into the left side of the freezer, Remove the 2 screws and the unit comes out. The power plug for it is just to the back bottom of the ice maker. If you can see it you can probably just unplug it to stop the noise.
Apr 11, 2015 | Refrigerators
KitchenAid KSCS23FTSS01 Ice Maker Not Working
Is it getting water? The inlet valve on the back of the fridge where the water line connects is a frequent source of ice maker problems. If the It sounds like you've covered the other major issues.
Nov 28, 2013 | KitchenAid Refrigerators
Green Ice from ice maker
Make be free copper pipe corrosion.
Jan 10, 2018 | Refrigerators
Black spots in ice for brand new installation
Crazy...
I would pat myself on the back a couple more days... and let the whole fringe get better (settle & wash out).
Just an errant thought...but if you have a water filter on your water supply I'm thinking I would rather know WHAT those spots were...
I'm thinking CHARCOAL (meaningless/harmless).
No FILTER = IRON OXIDE...
Means you have an advanced case of copper directly connected to steel pipe causing ELECTROLYSIS...
Find it fast or make sure your insurance is up to snuff.
I would capture a sample and test with a magnet
Some manufacturers suggest you toss the first load of cubes and go for it...
I think you are smart to watch what you ingest.
Carnac the Magnificent
Apr 20, 2017 | KitchenAid Architect II Series KBRS19KT...
How to reassemble ice dispenser parts od kenmore model 106.5706*602
Clean out the new ice maker with warm soapy water.
Ensure that the floor surface under your refrigerator is level. If the floor surface under your refrigerator isn't level, you can place shims under the legs of the refrigerator to fix the uneven surface.
Turn off the main water supply to your house.
Clear the water line by running the faucets until the pipe clears.
Screw the copper supply line's connector to the house's cold water connector valve. Use an adjustable wrench to tighten the connection.
Slide the compression sleeve and nut onto the other end of the copper supply line. The compression sleeve and nut will wrap around the outside of the copper supply line.
Bend the copper supply line to fit into the water line inlet casing located on the back of the refrigerator. Leave slack in the line so that the refrigerator can be pulled away from the wall or cabinets. The water line inlet casing is a plastic bracket used to hold the copper supply line in place so that there is no pull on the tubing's connection. It is the larger of the two plastic brackets located on the back of the refrigerator.
Insert the compression sleeve located around the end of the copper supply line into the ice maker connector. The ice maker connector is already installed on the back of the Maytag refrigerator.
Tighten the nut over the connection between the compression sleeve on the copper supply line and the ice maker connector with an adjustable wrench.
Attach the water supply tube clamp to the water supply line by clipping it into place. The water supply tube clamp is a plastic bracket located on the back of the refrigerator that holds the supply tube so that it doesn't rattle and become disconnected. It is the smaller of the two brackets located on the back of the refrigerator.
Turn on the main water supply.
Check all connections for leaks.
Position the drain hose located on the back of the ice maker over your floor drain. Use a PVC pipe if you need to redirect the drain hose flow so that it falls over the floor drain. The PVC pipe should not touch the drain hose and should have no low point where the water can settle.
Plug the ice maker into a 3-prong grounded outlet.
Feb 05, 2011 | Kenmore Refrigerators
Can I trigger the KitchenAid Superba KTRS25Q ice maker to fill?
THERE IS A WAY TO (JUMP) THE ICE MAKER BUT I DONT RECOMEND IT BECAUSE IF YOU JUMP THE WRONG WIRES YOU CAN DAMAGE IT. TAKE THE COVER OFF THE ICE MAKER AND LOOK IN THERE IT MAY SAY HOW. OR WAIT
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | KitchenAid Superba® (KTRP22KRWH) Top...
LG Fridge-Tube where water dispenses in ice tray is frozen solid
I think that the solenoid valve that supplies water to the ice maker is leaking ,it is located in the back of the refrigerator where you see a copper pipe or plasticpipe thatfeeds water to the refrigerator. Shut the water off and the power and take it out and replace it .
Apr 10, 2009 | LG Refrigerators
Ice maker not working
check to see if there is a bin switch one that checks for the amount of ice in the bin..replace or check that the nozzles arent blocked.
Nov 05, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KTRC22EM Top Freezer Refrigerator Logo
284 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
