Question about Rowenta Power Duo Iron
Rowenta DX 6650 leaks. How do I take it apart?
Water leaks from base. I need to take the iron apart to see about repairing the leak. Removing 4 screws did not immediately allow access. What is the trick?
BFixed
  • 104 Answers
SOURCE: Taking a Rowenta DX1900 Apart
Not sure about your model, but newer irons have the screws hidden under snap-on covers. Look for a small cover that may have a slot where you can insert a small screwdriver and lightly pry. Chances are you'll leave marks. They are not made to take apart so there is also a chance you'll break the internal tabs that snap/hold it together. You may be able to super glue them back. There should be a removable coverplate at, or near each end.
Posted on Mar 07, 2008
SOURCE: rowenta dx6700
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
Posted on Jul 31, 2008
wizzard8955
  • 18 Answers
SOURCE: My Rowenta iron will not heat up. The yellow light
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
Posted on Mar 06, 2009
wizzard8955
  • 18 Answers
SOURCE: iron leaks water from the back end of the base
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
wizzard8955
  • 18 Answers
SOURCE: Rowenta DM880 Auto shutoff - Shuts off too frequently
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
I iron, model 1306 is leaking water from the cornerback of the base. Can I repair
I can find no reference even by a shopping engine to an "I Iron" and specifically to an I iron 1306. If there is such a brand, you have offered more publicity than they have about it. If that is not the brand, it is best practice to list the brand in a query. Sadly, as I don't know anything about the brand, I can only offer:
My Rowenta iron constantly leaks water out of the bottom
Sep 01, 2017 | Irons
Leaking & no suddenly no steam available
the steam tank is leaking. Buy a new iron.
Jul 18, 2016 | Rowenta Irons
Leaking water around base
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
God bless you
Feb 03, 2013 | Rowenta Irons
I have a rowenta iron that leaks a lot of water
Here's a solution . . . Do NOT buy ROWENTA! I've had 3 Rowenta irons. All of them have eventually began to dump water out of the base. . . heck, the Titanic didn't leak as much as a Rowenta iron!
Dec 31, 2009 | Rowenta Perfect Iron
My Rowenta iron is leaking down by the cord. can
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Oct 16, 2009 | Rowenta Professional DE880 Iron
I have a rowenta iron. When I am ironing the
heatman101
Jun 25, 2009 | Rowenta DX6700 Iron
Iron leaks water from the back end of the base
Sep 26, 2008 | Rowenta Power Duo Iron
Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Jul 14, 2008 | Rowenta Perfect Iron
Rowenta Power Duo Iron Logo
145 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
