Question about Xerox DocuColor 12 Color Copier
Docucolor 12 error code HELP
The printer just stopped and an error code came up 9-357 The printer said to turn of and then back on. does not work. HELP would love to know the problem
  • Perfect12 Nov 10, 2007
    Hi There got a xerox problem, has an error code of 9-343 can you help?
  • Anonymous May 17, 2008
    I have the same problem. but how can i reset it.
    Sniper:
  • 56 Answers
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Posted on Nov 02, 2007
Error 10-162 please tell me say paper jam 3 and 4, there is no paper jam
Posted on Apr 03, 2008
Error code 004
Posted on Dec 11, 2007
If the error code comes up reset the code by turning it off then count 5 sec then turn it on if then ddnt work,ofen the front and see if theres pieces of paper stock underneith
Posted on Oct 03, 2007
  • 163 Answers
PLEAZ CHECK THE CARTRIDGES
Posted on Sep 16, 2007
SOURCE:
Error code 9 343
Error code 9 343 - Xerox DocuColor 12 Printer
Jan 08, 2014 | Xerox DocuColor 12 Printer
Error code 10-356
Hi
10-356 code i pws mode
remplace the fuser
Feb 09, 2010 | Xerox DocuColor 12 Printer
Error Code 10-399
Hello sir; The problem you have can be reset, just follow the steps as below;
1, power on the machine.
2, while hold down the 0 key, press start.
3, enter the access number 6789
4, click onNVM reset/NVM initialization.
5, enter 777-018 press start.
if still have problem let me know
Jan 02, 2009 | Xerox DocuColor 12 Color Copier
Xerox docucolor system fault problem
hi please chek and tell what error code showes in your display.. some error codes showing in ur display, pls check it that.
Aug 25, 2008 | Xerox DocuColor 12 Printer
Docucolor 12 system fault turn off and turn on problem
tell about error code which is appear left bootom of screen
Xerox docucolor 12 please power off and turn back on.
you have a heater problem. The machine times out if it doesn't see an increase in temperature within a set time. What code are you getting?
Xerox Docucolor 12
Error in the Fuser. The description for this fault code is: External Heat Roll Contact Failure. Generally the external heat roll retract motor is defective. The xerox part number of this motor: 127K21350
Aug 20, 2008 | Xerox DocuColor 12 Color Copier
Xerox dc12 error code 9-378
9-378 Drum Cartridge count expired (40K)
Aug 12, 2008 | Xerox DocuColor 12 Printer
Error code 10-162 docucolor 12
I honestly can't find that code in the documentation or I would have sent it to you.
Apr 03, 2008 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Color Copier Logo
1,227 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
