Question about Garden
Bosch Aquatak 100 hose won't stay on
I have tried 3 hoselok connections and each one comes off. Either water leaks out of it and after a minute or 2 the hose connection flies off or it comes off as soon as I turn on the tap. There doesn't seem to be much grip at the male connection end on the unit. Am I the only one with this problem or is it a common fault? - Su
SOURCE: bosch aquatak 120i pressure washer/tetergent
Hi Guys there isnt a problem with your machine you just need to pull the end of the spray lance out -the lumpy bit where the water exits the machine (it kinda clicks out)
Posted on Jun 27, 2008
  • 5 Answers
SOURCE: Technics SU-G90 Amplifier from the
because bad connections, probably in the driver section of the endstage, dc current apears on the output and shuts down the output through the relay.
info@lustinvest.nl
Posted on Aug 25, 2008
jonniewalker
  • 1031 Answers
SOURCE: There are two hoses coming
Many people realize the dishwasher connects to a little hose on the sink, it is called an air gap. However, many people wonder " The air gap is there to prevent the water from being siphoned out of the dishwasher. When water flows through the drain hose, it creates a suction on the water still in the dishwasher. The air gap, makes a hole for air to get in. That way, the water only leaves the dishwasher when it supposed to, when it is pumped out. Another benefit of an air gap is that if the drain hose becomes clogged, the dishwasher can still pump out the water. Instead of flowing through the hose, as it should, it can flow out the air gap and into the sink.
The dishwasher's drain line usually connects to an air gap mounted at the countertop level on the sink. The drain line continues from the air gap to either the garbage disposer or directly to the sink drain. If the drainage hose between the air gap and the drain is partially or completely blocked, wat
Posted on Aug 28, 2008
  • 17 Answers
SOURCE: Leaking from bottom
Are you sure its not leaking at the top? in any case
call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Posted on Feb 03, 2009
  • 1388 Answers
SOURCE: Had the Northstar 3000 psi Pressure Washer for 2
It is easy to check if your hose and quick connects are supplying enough water to the pump. Your pressure washer gallon per minuite requirements are printed on the machine and also on the pressure tips in GPM. Your post indicates 2.5 gpm but check your documentation of GPM. Next remove the tip from the wand and connect your hose with current quick connects to the machine. Start engine and direct the pressure wand into a bucket for exactly one minute. Measure the amount of water in the bucket, it should be very close to stated gallons. Do the same test with tip installed and compare measurement. If pump is starving for water you will not get proper amount of water in the bucket and the water hose will collapse. Two to four gallons of water per minute is not very demanding and should be delivered even with very small opening. You can even just direct the hose into the bucket for one minute and check how much water your hose is capable of delivering. I believe that you will find no problem with water delivery to pump. I would certainly enlighten Northern with your findings and question their evaluation. When you start using your pressure washer again try using it at lowest pressure to get the job done. Lowering the pressure to about 75% of max will increase the life of the pump and engine. Good luck with you pump
Posted on May 10, 2009
Bosch washing machine leaks
what size is the line you are using for the gray water. what i mean is if you are trying ti use the same size hose as the original discharge
hose, the pressure to high. the hose original was about 1 inch diameter, the hose use to go up than the hose hook shape goes into the drain pipe thats 2-3 inches diameter for draining the water went into the sewer system, if your trying to use 1-1/2 hose, the diameter not enough air or room for all that water. i dont think the lenth the issue its the diameter and amount of pressure that being forced down small hose or pvc pipe.
Oct 06, 2015 | Bosch Washing Machines
My pressure washer appears to have died.
does the motor have rust in it??the motor can be replaced
Jun 18, 2015 | Bosch AQUATAK GO Pressure Washer
Bosch aquatak
First off check your pressure wand / water nozzle make sure it's clean. if that doesn't help then it could be your water pump.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Jan 14, 2018 | Garden
A blockage in the inlet of an aquatak 115 plus.
nothing to worry about could be due to water intake,wear on nozzle or just the gauge
Oct 14, 2012 | Bosch AQUATAK 115 PLUS Pressure Washer
I have a Bosch aquatak 120i the motor keeps running all the time
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of time,not draining hose & machine, in the winter time the hose & pump will freeze causing hose & pump to expand and burst.handle to leak busting the o rings, build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps.thankyou. ~~
Feb 19, 2012 | Garden
Bought bosch aquatak 100 pressure washer. No manual or instructions in box. Store bought at cannot help.
Contact Bosch directly, they have been very helpful in the past.
Robert Bosch (Australia) Pty Ltd
1555 Centre Road
Clayton, VIC 3168
Phone: (03) 9541 5555
Fax: (03) 9543 5485
May 07, 2009 | Bosch Washing Machines
No Water
there may be a few things causing this, a blocked supply/transfer hose in the base, a blocked meter tank at the side of the dishwasher, turned off water supply, a faulty water valve,the unit is in "flood mode" and has a leak in the base and will not allow any more water in(check by tipping the dishwasher 45% sidewards to see if water leaks out or the water is coming in but you are not seeing it because the wash motor is jammed or seized.
Jun 22, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Garden Logo
855 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
