Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
My mtd tradesman lawn mower does not run smooth. where is the idle mixture adj. screw? the engine is the tecumseh 5.5 hp model #VLV55 501029A(D)
    President:
  • 1,902 Answers
The newer machines do not have a way for you to adjust the Idle, what you can do is change the spark plug or spray some carb cleaner or remove the air filter and run it for a few minutes without the air filter and see what happens
Posted on Apr 14, 2009
    Scholar:
  • 159 Answers
Change the sparkplug first gap it to .035.
Posted on May 26, 2014
I have Yard Machine 638 RL, Model 0V358EA, 13,5 hp. I want to change the Oil engine how many litter must put oil in the engine
The Tecumseh OV358EA 13.5hp takes one quart of oil, 32oz or 39oz with filter. Use 30W except if it is used in very cold climates. MTD makes a drain tool for around $5 that clips onto the drain plug area and allows you to direct the draining oil into a container with a lot less mess.
tom
Apr 26, 2012 | Mtd Garden
Need a manual for yard machine snow blower, model #31A-260-7310
Assuming that you have a Tecumseh engine on your machine, this should help you out a bit. Tecumseh also has some other very helpful documentation on their TecumsehPower.com website.
http://www.tecumsehpower.com/CustomerService/BSI.pdf
Nov 08, 2011 | Mtd 22" Yard Machine Push Mower
How to set up a carb with 31840 rebuild kit
what exactly do you want to know? Carb. mixture settings are as follows: L-head engines
Tecumseh carbs.........mainscrew 1 3/4 turns idle screw 1 1/4 turns
Walboro carbs........... mainscrew 1 1/2 turns idle screw 1 1/4 turns
L-head and OHV heavy duty engines 1 turns for both
Dec 21, 2009 | Toro Garden
Toro snowblower///// tecumseh# on motor is H35-45598R SER 5283B
Usually that is a sign of the carb not being adjusted right. Run it at full throttle and adjust the main mixture needle (usually on the bottom) until it runs the smoothest. Set it in the middle of the range where it runs smooth. Then set it down to idle and adjust the idle mixture until it runs smooth at idle. Accelerate it rapidly and if it bogs or hesitates turn the idle mixture a little leaner (clockwise) and try again until it works right. That should get you very close. Try tweaking it a bit from there. as the microscopic specks clean out of it, it may need more adjusting.
Nov 25, 2009 | Garden
8hp Tecumseh engine how to adjust carb. when I put throttle on high it sputters drop the throttle back down its okay?
These symptoms indicate a rich mixture. Assuming the carb is the original (and therefore correct) one, and that it has an adjustable main jet, turn in the main jet adjustment screw on the bottom of the float bowl until the engine runs smooth.
If there is no adjustment on the float bowl, the carb will have to be removed and properly cleaned (ultrasonic cleaner recommended).
Oct 01, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
I have an MTD 3.5 hp Tecumseh lawn mower. The
WHAT KIND OF OIL DO I NEED FOR THE LAWN MOWER
Sep 17, 2009 | Mtd 22" Yard Machine Push Mower
Is the carb adjustment screw on bottom
Hello
>>The Following is an Instruction File I made for Correcting this Problem. Any Input is Appreciated.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers.
>>There are Several Location for the Air Mixture Screws.
>>The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is the Nearest to the Engine.
>>The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>The Engine Idle Screw is Usually Easy to Identify because you can See where it Makes Contact with the Carburetor Throttle Shaft Plate Stop Ear. The H and L Air Mixture Screws Go Into the Body of the Carburetor and the Tips Cannot be Seen.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore).
>>If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required.
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns.****
>>Holding the Throttle Full Open, Start the Engine.
>>Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle.
>>Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle.
>>Reset the Engine Idle if Required. If This Carburetor has a Single Air Adjustment.
>>Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Rapidly Throttling from Idle to Full Throttle.**
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
These engines do not have an idle mixture adjustment. Most of the problems with them not running right are from bad gas, water in fuel, or carburetor jet deposits. If your fuel is ok, then you'll want to clean the carburetor metering hole. You'll want to either empty the fuel, or clamp the fuel line, but after that, take the nut off the bottom of the carburetor bowl. You will see holes both in the sides, and through the middle. Use a wire to clean these out, and some acetone or carburetor cleaner to get the rest of the deposits out, and you should be fine.
Apr 14, 2009 | Mtd Products Yard Machines 158CC Tiller
Mtd riding lawnmower won't run
my mtd lawn mower wont start . when I turn the key there is a buzzing soung where the battery conectors are near the shifter but the starter is hot and getting juice
Sep 28, 2008 | Garden
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
523 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
