Question about Husqvarna Zero Turn Mower Z5426
Husqvarna cth160 will not start after being driven into garage with battery diconnected
My cth160 drives ok for about 15minutes and then dies on hill. is this a transmission problem?
Does this unit have hydraulic drive? If so it could be that the oil heats up and then escapes thru worn drum surfaces. I had to replace my whole transmission on my John Deere X300R because it would not go upslope after 211 hrs work. I fitted K66 transmission which needed rebuilding the rear of my machine. If you are not an engineer with complete workshop, lathe mill etc do not attempt this. Buy a mower with a decent warranty and off a company which will honor it!!
Jul 17, 2014 | Husqvarna Garden
Battery warning light comes on when I start the car and doesn't go off until I've driven a few miles.
failing alternator. or bad battery have a free check done a a garage doing free checks on the battery if battery ok change the alternator. most places do a free check on batterys..
Sep 24, 2013 | Land Rover Freelander Cars & Trucks
Lost all power while driving. Jump started car but lost all power once again after I drove for a quarter of a mile. Do I need a new battery or do I have a problem with my alternator?
can be either on or both. if you have a volt meter handy get the car started and place the leads on the terminals on the battery, if the alternator is working you should have over 13 volts indicated.
Dec 14, 2010 | 1999 BMW 328 Series
I tried to start my 1996 328is. It will not turn over. Their is no noise at all, no lights, seats, doorlocks, etc...I haven't driven the car in 3 weeks but it has been in a coverered garage. I didn't...
Your battery was probably killed by heat, sitting and not being used and getting hot inside a garage will kill a battery, heat is a battery's worst enemy. No your altenator is probably not bad, test it with a meter by placing the red lead on the positive and black on negative, measure voltage before starting the engine, then again after starting the engine, before should be 11.5v-12.5v, after should be 13.5v-14.5v if these reading are the same on your car all is ok. Hope this helps, let me know.
Aug 08, 2010 | 1997 BMW 328
Hi I have a Husqvarna ride-on mower CTH160 which now has a problem. I am in rural France and it's difficult to find an engineer. BAsically the problem is that when you engage the cutting deck by pulling...
These machines used to use a Noram clutch brake, there are no service parts for these clutches so assumming the cable is pulling the engagement arm on the clutch then the friction plate in the clutch is shot and a new replaement is required.
Jun 01, 2017 | Husqvarna Garden
Randomly won't start, happened after jumping dead battery
Probably the battery. Take it the chain auto parts place and they will test it for you.
Aug 29, 2009 | 2007 Mazda B4000
Drive belt
I don't have an answer for you, but Do you have a diagram of the Drive Belt?
Mar 14, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Toyota Sienna won't start in -18F
I would replace the battery, purchase and install an oil filled battery warmenr, and purchase and isntall an engine block heater.
Dec 15, 2008 | 1996 Toyota Corolla
2001 dodge ram 1550 won't start
maybe its part of your fuel injecting drowning the spark to were it cant fire
Nov 16, 2008 | 2001 Dodge Ram 1500 Truck 2WD
2002 Blazer
the battery is shorted it will not take the charge be carefull for a shorted battery normally they stink dont make a spark cyhange it hope it help fixya our post thanks pierre
Jul 12, 2008 | 2002 Chevrolet Blazer
Husqvarna Zero Turn Mower Z5426 Logo
346 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
