Question about Dryers
No heat. The dryer tumbles but doesn't dry. No heat being applied at any setting. It is plugged in. Fuse box shows amp is on and working. Dryer turns on and runs full cycles. No heat still.
  • 2 more comments
  • hynstyl2005 Apr 14, 2009
    Its electric. I cant find much on the model either. Its a Kenmore electric dryer model # 110.86582100. I checked the vent duct...it clogged the mini-shop vac with lint. lol. Again this isnt mine but its in the house where i currently live. Im just trying to help them out. Plus I got two loads of wet clothes from monday. I also dont know of an appliance store just all the car parts stores. ???
    would an appliance store be able to test the heater element for me not attached to the dryer? I just dont have that tool .
  • hynstyl2005 Apr 21, 2009
    Evidently once i knew what to look for...it was just a disconnected wire. It seems that the female connector needed to be tightend on there. It works just fine now. heat works and its drying the first time. I'm guessing it was just loose so when the dryer was being used it would, over time, shake itself off the prong connector. lol. Simple fix and easy to spot. Thanks everyone for your help.
  • Jeff Adkisson
    Jeff Adkisson May 11, 2010
    gas or electric??
    if it is electric unplug the machine first then disconnect the heating element and measure resistance across the element if you get no resistance purchase a new element
  • 490 Answers
Yes they should be able to test it for you off of the dryer
Posted on Apr 14, 2009
    President:
  • 1,902 Answers
Check the glow ignitor located under the unit behind the back panel. If it does not glow, unplug the unit and remove the glow ignitor with a 5/16 wrench and go to your local appliance store and install and new one and everything will be fixed
  • Jeremy Reddick
    Jeremy Reddick Apr 15, 2009
    They should be able to test it but take a good look at it, if you see a white line on it it is cracked and needs to be replaced
MY Roper Dryer model # RED4340SQ1,Will Tumble but not Dry Clothes
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced
Apr 25, 2012 | Roper REX4634KQ Electric Dryer
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
My kenmore dryer runs but not drying and no heat.plz let me know waht i should do?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Sep 25, 2010 | Kenmore 63942 Dryer
The dryer works but does not heat up at all.
Hi
Electric Dryer---
Hope this helps...
Daniel
Sep 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer has warmth but clothes are not drying. vent is not clogged, temp set at regular,drum is turning What could be the Problem?
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 25, 2010 | Maytag PYE2300AY Electric Dryer
The dryer is not heating to dry the cloths.
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 20, 2010 | Dryers
My dryer is making too much noise and it's not even drying up clothes.
Hi
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Hope this helps...
Daniel
Sep 12, 2010 | Frigidaire FER311FS Electric Dryer
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
No heat?
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 06, 2008 | Danby DCD5505W Electric Dryer
Dryers Logo
131 people viewed this question
Top Dryers Experts
