Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Trouble code LE
New machine , no obvios blockages, LG SAYS ITS AN OVERLOAD PROBLEM, SCREENS CLEAN
  • 641 Answers
I believe that your error code is "IE". If so,its relates to water input problem Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You should replace it. Be aware you should disconnect the power cable from machine before doing it !!!! Good luck
Posted on Sep 13, 2007
  • Dov Dror Sep 13, 2007
    Thanks for your kindness and your appreciation for our try to help you solving your problem !!!
SOURCE:
Lg front load washer error le thermal overload circuit in mmotor
If the error code is "LE" then replace the hall/position sensor on the motor, if the error code is "tE" which looks a lot like LE at a causal glance then replace the thermistor that measures the water temp located on the bottom of the outer drum in front.
Aug 12, 2018 | LG Washing Machines
LG washing machine LE code comes up . WD14030D . What can I do to fix it? Claudia
LE code is an overload in motor. You might be washing too many items at one time. Towels are heavy when wet.
Dec 29, 2015 | LG Washing Machines
LG wm6042h washing machine. LE code for motor overload.
This is normally a common problem on LG tromms. The cause of this error code is as stated "motor overload" . The most common fix to this problem is replacing the hall effect sensor. But.... If you weren't getting this code before replacing the bearing I would recommend checking the sensor to make sure it's plugged in correctly.
I’m happy to help further over the phone at https://www.6ya.com/expert/george_083af2f0afc0328b
Dec 31, 2013 | Washing Machines
What does code LE mean? The washer stops and LE appears
Code LE signals an overload to the motor. Wait 30 minutes and restart the cycle. If the code is not released, you need to call a service technician.
Jan 07, 2011 | LG WM2487H Front Load Washer
I have letters le flashing on my lg front loading washer it won't spin
The code means the machine is not getting enough rinse water. Remove the hoses from the back i=of the machine, pull out screens, cold water is blue tab inside connection on washer, hot water is red. Clean screens and insert them back into the appropriate connection. Use a stiff brush and water to clean. Reset the machine by disconnecting power, press start/pause button(blue button on right) for at least five seconds, reconnect power.
Sep 25, 2010 | LG WM2277HBW XL Front Load Stackable...
Le error code on my LG washer.
On LG Washers the code LE is for motor overload protection.
Ensure that you are not overloading washer, make sure to clean pump by draining at little door at lower left corner(check manual for instructions), unplug for 30 minutes to reset, now try running cycle again. if it fails again something else is causing the motor to work to hard and will require a professional.
Apr 25, 2009 | LG WM-1832C Front Load Washer
Error code LE and OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged.
LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
Apr 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Lg thomm model wm2277hw machine stops on LE.
le indicates motor overload on lg machines if it is the direct drive machine replacement stator is very expensive at over £120+vat in the uk then there will be a fitting charge so might be worthwile considering spending the money on a new machine
Jul 19, 2008 | Washing Machines
LG washer doesn't work
Try looking it up in the user manual or you can try going to the manufacturer's website, look up the model and see if they have a manual or error code guide you can download.
Hope this helps!
Nov 28, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
96 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
