Question about AudioBahn A4125HCT Car Audio Amplifier
Status light red
I was driving the other day and my subs cut out. feeling akward driving down the road with no vibrations i pulled over and the status light on my Audiobahn A4125HCT was lit up red. My first thought was a short in a sub wire or terminal so i disconnected each one in turn and then both. With no subs connected the light was still on. I waited a day to see if it would snap out of it, but it hasnt. It never overheats because i have a 4runnner and i usually have the back window down while im driving. So today i tried bypassing the cap and wired it straight to the battery still with no subs connected and the red status light is still on. Id wonder if i blew the amp except i barely had it bumping when it cut out. Any other ideas?
  • 752 Answers
You may have your subs hooked up to it wrong. Either way the amp is definitely blown. Have a stereo shop check it out and examine your wiring.
Posted on Sep 15, 2007
SOURCE:
Why do I have bad vibration in my 06 impala?
Could be a vacuum leak. Buy a cheap vacuum gage and attach the hose to manifold vacuum port. Must be manifold vacuum not carb or anywhere else. The gage will tell you if you have vacuum leak. Then you will have to track down the source. Other issue might be starving for fuel but OK in park so maybe not. Good luck
Oct 26, 2016 | Cars & Trucks
Vibration coming from front axle when coming to a stop it gets worse, brakes are good , maybe cv joint?
if you feel the pulsation in brake pedal when stopping. its a warped brake rotor thats causing it. for bad cv joint symtoms--- Unusual noises when making turns. As you are driving on the road and you make a turn at the corner, if you start hearing unusual sounds coming from under the car then this is one of the symptoms of a bad CV joint. These noises will sound like something is clicking beneath the car every time you turn the steering wheel. Evidence of a damaged boot. Steering wheel feels heavier. The steering wheel will start to feel tighter and heavier and you can hardly make simple turns to the left or right. In severe cases you might even feel heavy vibrations like you are driving down a rocky road.
May 02, 2012 | 2004 Jeep Grand Cherokee
2001 chevy express van 3500 while driving security light comes on dash then engine shuts down , once pulled off the road it will start back up.. did this 3 times on hour drive.. feels like gas pedal just...
You need to get the codes from the theft deterrent module.Usually a B2960.This will help in the diagnosis of the problem.Hope this helps.Good luck.
Apr 07, 2010 | 2001 Chevrolet Express
I have audi a3 05 when starting feels like no power or going to stall,esp light comes on and engine managment flickers on after the first run the lights go off????
VW engines intend to do this, even if you pull up at a set of traffic lights it will nearly cut out or go into high rev's. i have an a3 & once driving down the road @ about 50kpm, I lost power stearing for 1-2 seconds, stearing wheel went stiff. Audi are a good drive but needs lots of tlc. One other thing is fuel pump could be acting up a bit.
Nov 22, 2009 | 2005 Audi A3
Steering wheel vibration at 65 mpr after I had master brake cylinder replaced. I have to pull off to side of road and stop car then start up again and problem stops. Can feel vibration in brake pedal when...
check balance of tires; if ok, have rotors refinished or replaced; most likely warped rotors if you can feel it in the brake pedal when braking
Oct 07, 2009 | 2004 Toyota Solara
Amp green then red light then nothing problem please help
It sounds like the output transistors have failed. To eliminate other possible problems, read through the following page.
Troubleshooting - Amp in Protect Mode
Let me know if you have any other questions.
Aug 05, 2008 | SPL Dynamics Z2X-1600 Car Audio Amplifier
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
AudioBahn A4125HCT Car Audio Amplifier Logo
149 people viewed this question
Top AudioBahn Car Audio & Video Experts
Dalynn Turner
Mike Duncan
Mike Duncan
Professor_V
Professor_V
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
