My Local Area Network icon Indicates that iam connected but i can't get internet.Sends few packets the received ones freezes. Andrew From Kenya
    Problem Solver:
  • 14 Answers
Log in as a Adminstrator
open the command prompt or click on run and type cmd , then enter.
Type the following commands
ipconfig / release
ipconfig /flushdns
netsh winsock reset
after you done , restart the computer .
It should work now
Posted on Apr 14, 2009
Iam having 2700 classic cell.i have subscribed packet data connection.it is connected to internet when the cell is connected to pc with usb.it is not connected to net on phone.why?
According to different types of Network available we should configure it by using the particular IP address.So if you can provide me your Network Name,Area (details) then I can surely help you.Thanks for visiting fixya
Oct 18, 2011 | Nokia Classic 2700 Cell Phone
MY compaq laptop will connect to a wireless network but when I connect to the Uni netwrk via the cable my computer indicates there is MAC address and won't work. Any ideas please, I have tried other cables...
Calm down, try this step. do you want to connect your laptop to cable network? if yes, then click on LAN icon on your task bar or you click on "My Network Places" once it open, click on view my network connections, there you see Local Area Connection which is your LAN device. Right click and point to Properties. There you see Options like Client for Microsoft Network, File and Printer Sharing for Microsoft Networks, Qos Packet Schedule, and Internet Protocol (TCP/IP). Click on Internet Protocol (TCP/IP) and then on Properties. Now you see options like "Obtain an IP address automatically and Use the following IP address. Click the second option which is "Use the following IP address" input the ip address like follows. IP address: 192.168.0.25, Subnet Mask:255.255.255.0, Default gateway is the ip address of your network, then input it there and the same thing with Preferred DNS server:also input the ip address of your network. Finally click on OK and wait a moment for the system to apply the settings. After that, you click on OK. Thanks and Goodluck..........
Jan 19, 2011 | Compaq Presario Notebook
Multiple network adapters found
Go to Start->Control Panel->Network and Internet->Network and Sharing center->Manage network connections
You will find icons like local area connection, wireless connection and lot more. Just have one local area connection enabled and disable all other icons. Then run the setup
Nov 01, 2009 | Belkin (F5D5231-4) Router
Internet Won't Connect
Press Start->Connect To -->Show all connections.
If the Local Area Connection icon is crossed with a red X, right click it and choose (Enable, or Repair).
If there is no Local Area Connection icon, you must create a connection.
In the left panel in Network Connection window click create new connection.
1.The wizard pops up
2.Click Next.
3.Put a (dot)mark in Connect to the Internet .
4.Click Next
5.Choose Set up my connection manually
6.Click Next Choose the type of connection you have with you ISPN (dial up, etc.)
7. Click Next , and follow the instruction from here.
Hope it helps you find your way to a solution
Aug 30, 2009 | E-Machines Computers & Internet
Unable to find a local connection icon in my HP computer--
check for the ethernet cable attached to this computer. try doing the loop back test
start->run->type cmd-> type the command ping 127.0.0.1
If u get 4 packets sent recived 4 then everything is fine u have some browser or OS issues else if u see 4 packets sent and lost some then prb with the network card or the ethernet cable.
Jun 17, 2009 | HP-HSC HP-IB Interface (E2071D) Network...
Wireless connection problems, not receiving packets.
Goto Network Connections >> Right Click on the wireless icon >> Properties >> Select IPv4(or IP for XP) >> Click on Properties >> Now see from your friend's system(in the same way) if here the details entered MATCH. The DNS entry shud match here.
May 25, 2009 | Google Chrome
Dell Ethernet Network Adapter not being recognised
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:  Local Area Connection 1 or 2 or 3
        Network Cable Unplugged, Firewalled
        VIA compatible Fast Ethernet
        in this case u can download VIA network drivers....from internet..
                      or
       eg2: Local Area Connection 1 or 2 or 3
       Realtek RTL8139 Family Fast Ethernet NIC
       in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing              model no: RTL8139 through google search engine )
                                         (OR)
ii)        Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select                Network Adapters....
           but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the             correct Model NO: of VIA or Realtek....
            so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Nov 23, 2008 | Dell Ethernet Card Network Adapter
I want to connenct w200i with pc
please activate mobile office service from your network provider and later on you can connect your mobile to comp for internet surfing...please contact the customer care of your network......
thank you
Nov 03, 2008 | Sony Ericsson W200i Cellular Phone
Hiii sir
some softer drivers are included under windows, some are not, like for example your network drivers arent. u will have to install them manually from the CD that came with the motherboard.
Hope it helps
Z33m
Dec 10, 2007 | Mercury P4VM800M7 Motherboard
Computers & Internet Logo
David Payne
David Payne
