Rank: Guru
Rating: 90%, 646 votes
Ok so you have the cabinet removed if you can see the pump. That is the hardest part of changing this pump..
1 with a flat screwdriver remove upper and lower retainer clips.turn them 90 degrees and clips will slide out. remove pump from motor
2 get a bucket to catch the water. with pliers remove both hose clamps then pull off hoses.you have just removed the pump. when reinstalling I like to use screw hose clamps much better then spring hose clamps. just so you will not have any leaks... Hope this helps let me know..krazytech
