Question about Nintendo DS Lite Console
Top screen has horizontal and vertical lines
Top display monitor has vertical and horizontal lines
    Scholar:
  • 133 Answers
The only solution is to replace this top screen.
Buy.com has the top screen for $20 Bucks!
Search Top Screen Replacement Display on there.. Hopes this helps.
Posted on Apr 14, 2009
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Vertical strip of flashing horizontal lines on Acer Aspire 7551G screen
More than likely it's the lcd screen and will have to be replaced. I could be the video card, but most likely the lcd screen especially when you can put pressure on the screen and cause changes. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok, then the problem is with your lcd screen and the video card is ok. If the Borrowed monitor displays the same as your lcd screen then the problem is with your video card inside the computer.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Once you narrow it down to the lcd screen as being the problem you might try taking the lcd screen apart to reseat the lcd cable on the back at the top of the lcd. Just unplug it and plug it back into the connector. You can also try doing the same where the lcd cable plugs into the motherboard. Just pull it out and put it back.
May 31, 2012 | Computers & Internet
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
"Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 27, 2010 | ViewSonic VX2235WM Monitor
No pitcure display only horizontal line appears
Hi and welcome to FixYa,
The horizontal line indicates failure in the vertical section. Almost always, this would be a faulty vertical IC. In some instances, it can be or may include the diode, limiting resistor and filter capacitor coming from the FBT providing the Vertical B+ ~ 28VDC. You would need a DVM/VOM to check for the presence/absence of voltage.
Good luck and thank you for using FixYa.
Feb 15, 2009 | LG Flatron F700P 17" CRT Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
On the monitor, only one straight horizontal line display on screen. How to fix it?
Sounds like it's not scanning vertically, probably not worth the money to have a monitor fixed. Time to get an LCD. :-)
Jan 11, 2008 | HP D2835 17 in. CRT Monitor
Nintendo DS Lite Console Logo
282 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
