Question about Nokia N82 Handheld
DATA TRANSFER WHEN I CONNECT DATA CABLE TO PC, IT SHOWS "UNABLE TO ACTIVATE DATA TRANSFER BECAUSE MEMORY CARD IS ACTIVE IN SOME OTHER APPLICATION.MY PROBLEM IS HOW TO FIND OUT THAT APPLICATION?
    President:
  • Nokia Master
  • 2,923 Answers
Usually if there's an application going on to the phone, you will see an additional icon on the upper part of the screen.
Try to turn the phone off and remove the battery for about 20 seconds. Put the battery back and turn the phone on.
Reconnect your phone using the USB data cable to see if you will get the same problem.
Posted on Apr 16, 2009
Hai.I have a Nokia N 95 8 GB.it's data transfer option is not working recently.The reason showing is that"unable to activate transfer mode.Mass memory is in use by another application"Pls...
It is possible that the phone has are errors in the software/memory card. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Jul 05, 2011 | Nokia N95 Cellular Phone
Hoiw do you upload you pictures off your phone to your computer
Hi there !
1. First you need to install the PC suite software for your mobile (e.g. Nokia) to your computer. After installing, click the pc suite icon and connect your mobile phone using a usb data cable. Then you are ready to transfer data from your mobile to your computer and vise versa.
2. If your computer had bluetooth device, just activate your mobile bluetooth and your computer bluetooth device. Have it paired and it recognized your mobile phone by the computer, you can not transfer the data from mobille to computer and vise versa.
3. Another is by using memory card reader in your computer. If laptop have memory card reader, you can use it by removing your SD memory card and insert it to your computer's memory card reader. You can upload pictures from your memory card.
I hope it helps you and thank you for using Fixya !
Jan 08, 2011 | Computers & Internet
My nokia 5700 cant accept files via bluetooth transfer... it says memory full. even after deleting some songs
your phone memory is full... if you are transfering huge file then it won't be accpted...i recomande you to go
menu>>message>>option>>setting>>other>>memory in use...
try to change it from 'phone memory' to your 'memory card'..
it will ask u to copy the new msg to memory, so press yes and yes for to save the original message.
all ur message will be copied to the memory card...now you can recieve more file depending on the memory available in your memory card.
There is still a problem here!!!! When you will connect your mobile to a pc it will say "unable to activate data transfer mode ...bla bla bla...." so you will have to change memory in use option everytime to phone memory then try to connect it to ur pc...
thanks.. regard from Nireshis
Oct 24, 2010 | Nokia 5700 Cellular Phone
While transferring mp3 it shows an error
basically nokia mode is meant only for those if u want to use ur for for internet nad short term applications..........for storage purposes data storage mode is used
Sep 03, 2009 | SanDisk 2GB Secure Digital Memory Card
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
Unable to install Java games on P520
we can transfer the java games by using the data cable. following are the steps 1. connect the mobile with the PC by using the data cable 2. transfer both jad and jar files to the "MTP" folder in the memory card of the device. 3. disconnect the data cable 4. go to "my files" menu 5. go to  the "memory card"  5. move both the JAD and JAR files to the "phone"  6. get back from memory card to my files
device will ask for the installation of the game. if not, follow the steps below.
7. select the "other files" folder
8. select the JAD file.
the installation prompt will be displayed
        Ranil S.        SIPL
Dec 22, 2008 | Samsung SGH-D900 Cellular Phone
N95 8GB.Problem in connecting the phone through USB cable
I suspect the message you're receiving is:
"Unable to Activate Data Transfer Mode. Mass memory is in use by another application."
It's likely that several applications are running in the background of your phone. I believe the N95 runs on the Symbion OS. I'm not sure how to walk you through pulling up a task manager application to manually close the running applications, but the simple answer to this problems is for you to turn your phone completely off and turn it back on again. This should close all the applications that were running in the backgound.
Hope this helps.
MO
Jul 13, 2008 | Nokia N95 Cellular Phone
Phone memory & Active sync problems
1. Not sure why its not syncing. You may try uninstalling active sync from your computer and reinstalling.
2. Get another memory card and put the files on there, or get a card reader and transfer them to your computer.
Uninstall any unnecessary programs from the phone to free up space.
May 30, 2008 | T-Mobile Wing™ Smartphone
Cable driver for IMATE PDAL
I HAVE SOLUTION FOR IT
TWO SOLUTION
1 FOR DATA TRANSFER USE SOFTIC CARD EXPORT
2 FOR INTERNATE ACSEEC AND DATA TRANSFER INSTTAL ACTIVE SYC. IN DESCTO COMP.
FOR MORE INFORMATION CALL ME
919228189932 DINESH CHAUDHARI
Mar 12, 2008 | i-mate PDAL Pocket PC
Hi..i have a problem with the memory.
Some times phone memory data has support files in memory card and vice versa. Your 6233 have just 6MB phone memory. Try to transfer the phone memory data to memory card or PC. Check which made your memory full. Check whether you have Blue tooth data in inbox. if your Phone memory is full you cannot perform some phone application. try to erase some un neccessary data in phone mode itself withourt connecting to Pc suite applications. after data removal try to connect with Pc suite. Now you may transfer your phone data. if problem still persists contact authorised service personnel. All the best !
Nov 11, 2007 | Nokia 6233 Cellular Phone
Nokia N82 Handheld Logo
67 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
